I milled this part last night using the built-in "Shapes" wizard by German Bravo in Mach 3 (registered version). I used the circle function with a 0.75" radius and the G-code tool-path window showed what appeared to be a perfect circle. I milled the part and noticed that something is wrong. The x-axis seems OK - it was 1.493" in diameter. However, the Y-axis of the circle was WAY off at 1.315". Any thoughts on what the problem could be or how I can further diagnose? FYI I was cutting Delrin, 1/4" 2-flute endmill, 0.1" cuts at 1,000 RPM. Mill sound ed fine through the cut and cut the shape wrong, but consistently wrong on each pass. Thanks!
__________________ Tormach PCNC 1100, SprutCAM, Alibre CAD |
| check your motor settings, looks to me like if your x and y motors, gearing and screws are identicle you have different settings in the steps/inch setting... if the x and y arent the same, ie different pitch screws, or different gearing or something like that then you need to redo the math for your steps per inch settings... one other thought, what kinda drivers are you using.. maby one is set for a different level of microstepping than the other? like 1/2 on one and 1/4 on the other or something like that...
__________________ Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino. |
| Backlash or motor tuning problem? How do I test for backlash? | Brian Queen | Mach Mill | 8 | 03-10-2008 03:35 PM |
| A axis backlash problem | Art Ransom | General Metal Working Machines | 0 | 09-11-2006 06:38 AM |
| Backlash Question | scratch_6057 | DIY-CNC Router Table Machines | 3 | 06-15-2006 03:32 PM |
| backlash question | arsenix | Bridgeport and Hardinge Mills | 4 | 11-01-2005 12:25 PM |
| Backlash problem | devincox | Benchtop Machines | 6 | 08-17-2005 01:10 PM |
