Results 1 to 5 of 5
Thread: Wiring up CNC Electronics
    May 2006
    Hi Guys,
    Looking to finally wire up my PMDX-122 to my four IMService Driver cards. Here are a few pictures of all of them. Any help would be greatly appreciated- If someone can come up with a wiring diagram, that would be incredible! Here is a link to the PMDX's manual.
    May 2006
    Bump- Halp!
    May 2006
    Bump, really need some help!
    Jan 2006
    Hey burn, it seems pretty straightfoward. On your breakout board each of the pins correspond to a number of pin from you parrallel port. So, pins 2&3, 4&5, 6&7 would run from the breakout board to the step and direction pins on your drivers. Pins 2,4,6 would run to the corresponding step on your drivers, x being number 2, y being 4, z being 6. The Direction pin would then run from 3,5,7 on your breakout board to again the pins on your drivers, x being pin 3, y being pin 5, z being pin 7. Your servo boards have the abbreviation stp and dir for step and direction. Because your servo boards use a particular connector you would either have to solder the wire directly to each pin or find a connector that would work. You could prolly find the connector at any good electronics hardware shop. What other questions?
    May 2006
    Thanks for the help PizzaMaker
    Got an email from Steve Stallings over at PMDX:
    Based on Fred's comment about 500 mA typical power
    consumption for his boards and encoders, the PMDX-121
    cannot supply the 5 volts.
    You can use power from a disk drive connector in the
    computer but I would recommend an independent power
    supply. The ground lead is typically black and should
    connect to the GND terminal on J8 of the PMDX-121
    and to the GND of the middle connector of the servo
    board. The 5 volt lead is typically red and should connect
    to the "+5 Aux Out" terminal of J8 on the PMDX-121 and
    to the +5v terminal of the middle connector on the servo
    board. The encoder will get its power from the connector
    on the servo board. Even though the terminal on the
    PMDX-121 is labeled "+5 Aux Out", it is permissible
    to supply regulated 5 volts into the board on this pin. Do
    not connect an unregulated supply or AC to this terminal.
    JP1 on the PMDX-121 should be set to the GND position
    for use with these servo boards.
    Regards,
    Steve Stallings
    PMDX
    1. I need to know everything about CNC Electronics
      By alanfreefall in forum Servo Motors and Drives
      Last Post: 07-19-2007, 09:56 AM
    2. CNC Hardened Electronics
      By Too_Many_Tools in forum General Electronics Discussion
      Last Post: 05-24-2006, 07:23 PM
    3. Electronics
      By Bassbuilder in forum General Electronics Discussion
      Last Post: 11-15-2004, 10:34 PM
    4. Help with electronics 101
      By bb99 in forum General Electronics Discussion
      Last Post: 11-14-2003, 06:03 PM
    5. Electronics help
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 07-18-2003, 10:09 AM
