Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: Seig X2 head to gantry
    Jun 2007
    I've got a Seig X2 and have used it for CNC using a small X-Y stage that I mount on the bed. It has always been my temporary solution before going bigger.
    Attached is my first attempt. I'm building it in Autodesk Inventor before making chips so I can test out the motions. I have a clean 12" by 24" throw right now on X-Y, but I can't decide on the Z. I have thomson rails and bearings (SPB10-OPN) for all X-Y and I have two 17" IKO rails with three sleds (LWL12 B) each for the Z. The table surface is an old cast iron router table.
    I "think" I can build a fairly stiff metal working machine with these parts, but I could sure use some advice if someone sees a problem lurking.
    Machine is mostly used for milling out small aluminum 1/32" faceplates, the type that are used for outdoor electrical box covers. I usually group them in a stack of 10 to speed up my production by doing 10 in a shot. My present Seig mill is actually good enough for this, but I want to start doing some larger 10" by 12" size reverse etching of acrylic panels.
    So here is my first question: What is the general consensus on how high of a clearance I should have on the lower gantry rail. Obviously in my present design the spindle can't reach the table, but if I lower it then the rail might interfere when coming forward. With 17" rails, I think I'll always be able to go up for bit changes. Should I just leave the lower rail at about 8" and mount all of my items to be milled on jigs? After all, I never really want to drill or mill the table surface.
    Mar 2005
    ENGLAND
    I won’t question why you are using the X2 spindle and will assume you will be happy enough with rpm’s as you have been using it already.
    As for the Z axis; only you will know what a suitable height is. This will need to be worked out from cutter lengths, material thicknesses + jig height and clamping methods. I would recommend you having a good think about what is likely to be your highest setup and workout how much clearance you will need on the Y axis. It might be a good idea to add some extra for just in case situations. Obviously the lower you can keep it the better so keeping the jig base height to a minimum would make a difference to Z and Y axes rigidity.
    John
    Registered zephyr9900's Avatar
    Feb 2006
    Those Z rails are pretty long. Would you get more useful travel if you put the sleds on the X carriage and have the rails travel with the Z head? I.e. make a tall plate with the Z rails at the edges and mount the headstock at its bottom end?
    Best regards,
    Randy
    Mar 2005
    ENGLAND
    Quote Originally Posted by ProtoTrains View Post
    Best regards,
    Randy
    I was presuming the drawing was a draft and not the final design? So did not really look at the picture.
    John
    Jun 2007
    Good points.
    Seig X2 spindle has the belt drive modification for higher speed. I find it fine for everything I have done so far. I like the R8 collet and the ability to reduce speed while maintaining good torque.
    I don't actually plan on doing any milling at the top of the Z stroke. I simply want to ensure that I can always lift high enough to change the R8 collets. I have found this to be of particular concern when using the original Seig mill and the drill press collet adapter with a long drill bit.
    I plan on beefing up the Z with metal plate. I just haven't added it to the drawing.
    Jun 2007
    If you mount the Z rails to the traveling head, then your head can't ever go higher than your lowest bearing. Yes, you can travel all the way down, but not up.
    Feb 2006
    Quote Originally Posted by lasersafe1 View Post
    Sure. But you would place the sleds differently on the X carriage than you have them now.
    It seems to me that your Z travel ideally will be equal to the distance between the base and the bottom of the gantry plus your longest tool length. I.e. be able to touch the base with your shortest tool and just be able to retract your longest tool to the bottom of the gantry for clearance. John gave the guidelines for working out the gantry clearance.
    On my Techno-Isel gantry I mostly held thin sheet with double-sided tape on a sacrificial aluminum tooling plate that I screwed to the table. I also had taller work that I held in a toolmaker's vise. I was using a Sherline milling head for which I made an adapter plate to fit in the T-slots in the Techno Z axis carriage. Depending on the height of the job, I slid the adapter plate up or down in the T slots. That worked pretty well becasue I didn't have enough Z travel to do it all in one setup. There are a couple of photos at http://www.prototrains.com/gantry/gantry.html
    Best regards,
    Randy
    Jun 2007
    I see what you mean Randy, but my difference between tool sizes can be substantial. An R8 collet with 1/8 engraving bit vs. the 1/2 drill adapter collet with a 1/2 drill inside can be a difference of 7 inches. In order to quickly pull this latter collet I have to raise the head 12" from the work surface. I realize that I might have to beef things up, but acme thread is cheap and if I can make the Z lift higher to avoid manual adjustments then it is preferred.
    Of course I could always put a hole in my table over in the corner to let collets drop through.....
    Feb 2006
    Looks to me like your table already has a hole... Just don't put your gantry leadscrew exactly in the center...
    Best regards,
    Randy
    Registered fatal-exception's Avatar
    Mar 2006
    Hey, I'm in the same boat as you. I'm about 1/2 through my design, and am kinda unsure about how much head travel I should build in. I've designed it so far that neither the coller holder, nor drill chuck can crash into the table without tools. I don't have the ground rails yet, so I'm still flexible there.
    I agree that it's is a personal choice, and one that should be driven by what you plan on using the machine for. If all you ever do is sheet material, you really don't need much travel. I've planned on 7" of travel, which should be plenty for milling and drilling sheet plastics. I'm sure there will be a time in the future that I wished I had more, but that's neither here nor there.
    Anyways, that' my 2 cents.
    Attached Thumbnails Attached Thumbnails Seig X2 head to gantry-bd-cncmc-headdown.jpg   Seig X2 head to gantry-bd-cncmc-headup.jpg   Seig X2 head to gantry-bd-cncmc-perspective.jpg
    Feb 2006
    Unless you have really deep holes to drill, CNC-length drills are great. I bought a whole set (number, letter, fractional) when I had a Sherline mill and still use them with my Tormach. They are short and stiff.
    For that matter (not knowing your budget nor what you already have invested in tooling) have you seen the Tormach Tooling System? It uses a flat-faced R8 collet to hold toolholders in which you can preset mills, drills, etc. The vertical clearance required to change tools is much less than changing R8 collets, and the ability to use preset, repeatable tools in multi-tool programs is sweet.
    Best regards,
    Randy
    Oct 2005
    Well that makes three of us at the same stage. I am working through the design problems. My biggest concern is having the weight of the X2 head sitting out so far from support. I see both designs have done what I did and remove the dovetail casting to reduce the weight. I have the pulley kit fitted and all the gears stripped out but it still weighs in at 9kg less the switch box and motor controller. These items I plan to mount on the Y axis and just extend the motor cable.
    For changing the R8 collets I am going to either drill a hole in the table or pivot the head so it can be turned to 90 degrees (maybe less) to clear the collets.
    I was planning on Z axis travel of between 4 to 5 inches.
    My choice to use the X2 head is to reduce noise so that I can work later into the night. The routers and die grinders are not making me popular with the neighbors.
    I am pleased to see a couple of others that think the X2 head is a good way to go.
    Are you planning on using flood coolant?
    cheers,
    Rod
    Perth, Western Australia
  • Page 1 of 2 12 LastLast
    1. Opinion of Seig C6B lathe
      By paulC in forum General Metal Working Machines
      Last Post: 09-19-2007, 04:20 PM
    2. RF31 CNC Kit or switch to Seig X3 CNC or ??
      By Gene-Yo in forum Benchtop Machines
      Last Post: 11-13-2006, 02:33 PM
    3. What to Do w/ My Seig X1 Stock
      By mabmojo in forum Benchtop Machines
      Last Post: 07-14-2006, 12:02 PM
    4. Seig X3 Y-Axis
      By bigbigJimbo in forum Benchtop Machines
      Last Post: 07-04-2006, 01:02 AM
    5. Conversion to programable independant heads for Gantry Twin head router table
      By ohallock in forum DIY CNC Router Table Machines
      Last Post: 04-18-2006, 07:20 PM
