Old 10-04-2007, 07:32 PM
juno is on a distinguished road
Lamest maching question ever -- mill reach
I blame my stupid question on being a girl. Just kidding. I blame it on a lack of machining experience.
I performed a draft cut of a part tonight with the .125 flat end mill. It looks good. When I swapped it out for my .032 ball end mill, I began thinking: won't the taper where the end mill meets the larger shaft that goes into the collet cut into my part? The part is deeper than the .032's reach.
Am I condemned to only machining parts within the end mill's reach or with a curve or a step or is the MDX software smart enough to know it's going to cut in and avoid that area?
Help!
Old 10-04-2007, 07:45 PM
SORCHEROR is on a distinguished road
you have to relieve the endmill back far enough to clear,but remember you can only cut so deep with a small endmill,and need to take smaller cuts as is can deflect alot easier no that is relieved
MACH 3: Can't reach defined speed nessie_bg Mach Mill 7 11-20-2006 03:20 PM
Components for CNC maching Esses CNC Wire Foam Cutter Machines 2 05-24-2006 01:28 PM
Cheap CNC for maching aluminum debutis Parts for Radio Control Models 6 09-11-2004 04:38 PM
high speed maching h13 turkgeltz Hard and High Speed Machining 7 04-14-2004 01:30 PM
maching bushings SWHITE Employment Opportunity 1 03-10-2004 09:46 PM
