Old 10-03-2007, 07:13 PM
maxboostbusa is on a distinguished road
X2 R8 Drawbar length???
Bought a mill from a member on here its a X2 R8 machine. It has the 3/8- drawbar from a MT2-3 machine. It states R8 on the Id tag. What length is the stock drawbar. I need to fashion up a bar until I can get one here from little machine shop. Next day air is to expensive from Cali. to NC. Unless somebody nows a place to get one closer to the east coast. Grizzly doesent list one in there parts breakdown that I have found yet. Thanks everybody.
Old 10-04-2007, 10:09 PM
OK figured out in a total pinch you can use a 7/16-20 6 inch Grade 8 or L9 bolt, which is what I used and 2 L9 7/16 flat washers to secure an endmill holder. Has enough pull so that you still have to rapp the bolt with a brass hammer to get the holder loose. Should be OK for the light cuts I need to make now until my real drawbar arrives from LMS.
Where to buy a drawbar? MrWild Bridgeport and Hardinge Mills 3 07-31-2006 06:44 PM
Automatic Drawbar Help Barry_ward General Metal Working Machines 10 06-25-2006 06:57 AM
power drawbar fourperf Bridgeport and Hardinge Mills 3 03-21-2006 08:28 PM
ElectroMagnetic Drawbar? DennisCNC Mechanical Calculations/Engineering Design 17 01-09-2006 11:01 PM
Having trouble with the X2 drawbar. spoonerb Bridgeport and Hardinge Mills 2 12-19-2005 03:28 PM
