Old 09-25-2007, 08:14 PM
dleroi is on a distinguished road
Spindle Lock for Belt Driven X2
In preparation for my CNC conversion, I installed the LMS belt drive kit. I'd read it was a 20 minute job, but mine was more like 2 hours. The threads on the spindle were mangled, as though someone had turned the spindle nut without loosening the set screw. Anyway, I spent some time dressing those threads and then I decided to remove the transmission gears, as well. I figured they could still cause problems (not to mention noise) as long as they were in there. I guess 2 hours isn't bad, considering the extra work I did.
Anyway, the last thing I wanted to do was to take it back apart to drill holes for a spindle lock, so I came up with one that uses the holes in the support block of the Z-axis micro feed.
I used a scrap of 3/16" aluminum for the support and turned down a 3/8" bolt for the lock pin. With a spring on one side and a locking collar on the other, it's smooth as silk. It isn't elegant, but it's simple and effective.
Parts for the CNC conversion (Hoss clone) started arriving today!
ID:	44260   Click image for larger version
ID:	44261   Click image for larger version
Old 09-26-2007, 11:01 AM
cota is on a distinguished road
[QUOTE=dleroi;
Parts for the CNC conversion (Hoss clone) started arriving today![/QUOTE]
Is someone selling kits from hoss's plans? Do tell, I know he won't sell complete kits. could save me a lot of trouble.
charlie
Old 09-26-2007, 01:42 PM
charlie
Charlie,
Not to my knowledge. But, Hoss sure makes it easy to order the raw materials - what with vendors' part numbers and all.
It would be really nice just to get the pieces that need the 15/16-16 tapped threads.
I've read where Hoss has machined the harder stuff for other people, though. I wouldn't hurt to ask him.
Hoss?
- Don
Old 09-26-2007, 01:59 PM
Runner4404spd is on a distinguished road
if there is enough demand i can whip up the parts you guys need, i already have the 15/16 x 16 tap. with hoss permission of course.
Jerry
Old 01-25-2008, 05:21 PM
menzies99 is on a distinguished road
Hi there dleroi,
My question for you is ----With the LMS kit fitted and the Hoss clone gear fitted is there a problem with clearance between the side of the motor and the z axis ballscrew mount plate? Probably not but I like to check on such things ahead of time to reduce the quantity and magnitude of my modification errors.
Old 01-26-2008, 12:32 AM
maxboostbusa is on a distinguished road
It may be close on the motor to z axis mount. I have his design belt drive and have about .125" clearance. You could increase the clearance by removing the rack for the z course feed wheel and moving the electronic box off of the back then you could mount the brackets a little farther back. Hoss is selling material kits now with and without the fasteners needed on his site. I think its like $85 for the raw stock and fasteners but dont quote me on that just check the site.
Old 01-26-2008, 08:51 AM
hoss2006's Avatar
hoss2006 is on a distinguished road
Originally Posted by menzies99 View Post
Hi there dleroi,
I forgot to post this pic on the other thread that shows the clearance
between the motor and bracket.
Like Max said the bracket could be mounted farther back on the column if you remove the Z axis rack.
Hoss
Name:	belt conversion motor clearance_1024x768.jpg‎
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 01-29-2008, 06:37 PM
Hi there dleroi,
Menzies,
What they said! Sorry I didn't notice your post sooner.
- Don
DIY spring loaded engraving tool holder cut more Engraving Machines 25 12-07-2009 12:34 PM
belt driven CNC table? (I have pictures) rcbamm DIY-CNC Router Table Machines 23 06-23-2009 08:04 PM
Belt driven screw ? tomcat47 Linear and Rotary Motion 10 01-29-2007 10:20 AM
spring loaded rack and pinion dgalaxy CNC Plasma and Waterjet Machines 4 12-03-2006 11:49 AM
Spring Loaded Rack and Pinion request ty1295 CNC Plasma and Waterjet Machines 1 02-07-2005 11:15 PM
