  #13   Ban this user!
Old 10-03-2007, 05:09 AM
project5k's Avatar
project5k is on a distinguished road
it just so happens that i have some 1/2" tp t6061 around here, i was planning on using it to make the spindle mounts for my 3x3 router... i dont remember the dimentions, but maby i should check to see if it fits for this application before i cut it up for the router... thats a really easy fix, thanks... i could just chuck up a drill in the mill, draw out the hole pattern and let it drill all the holes, then i'll have to tap em.. or maby, drill it from the backside, countersink em bit, and use some threaded inserts... hmm that sounds like the way to go rather than tapping 100's of holes...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  #14   Ban this user!
Old 10-03-2007, 06:17 AM
digits is on a distinguished road
I'm sure I saw a table on here that had a matrix of holes that were drilled through, countersunk on the rear side, and then had flange-nuts press fitted into each hole - simple, cheap and effective. If you have a pile of threaded inserts, I suppose they'd be even better.
  #15   Ban this user!
Old 10-04-2007, 05:20 AM
project5k's Avatar
well i cant imagine that thier that expensive, might even pick them up for around $.25 each or less, i havent looked, but surely the big orange box or my local nut and bolt shop can get me what i need at a price i'm willing to pay.. just have to go and ask the questions and look around.. but i'm thinking that this just might be the way to go.. time to do more research.
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 02:55 AM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 01:01 PM
Spindle Motor Help Ringleboy26 General Electronics Discussion 3 01-03-2007 11:25 PM
Spindle Motor for my cnc? Cooper Open Source CNC Machine Designs 1 12-10-2006 01:11 PM
DC Spindle motor Phooey Bridgeport and Hardinge Mills 9 09-26-2005 12:02 AM
