  #121   Ban this user!
Old 10-31-2007, 05:15 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
Made a little video here to answer a few questions.
The spindle and bearings are deflected by this type of power drawbar.
Total movement was .0025 inch.
It does return to zero on release each time.
Should be no big deal especially with the rigid tool rack
I'll be using.
The spindle will rest against it when the drawbar is activated so it shouldn't deflect then.
The collet drops about .060 inch at release.
The tool holder is held pretty tight by the springs.
I tried to rotate it with an allen wrench while holding the spindle lock.
All it did was bend the allen till it popped out.
Hoss
http://www.hossmachine.com
ID:	46130   Click image for larger version
  #122   Ban this user!
Old 11-01-2007, 01:16 PM
Bob Adams is on a distinguished road
Thumbs up My ATC
It's Alive thanks to Hoss!!!
I had to make a few changes.
1. I have a Harrison belt kit, the pin comes out the side.
2. The drawbar had to be changed a little, because I didn't have enough threads in the collet. Cut the drawbar back about 5/16 for the spring washers, then tapped a 1/4-20 for a lock washer and allen bolt.
3. I cut a hole and slotted the side plate. Now all I do is take out the two back bolts, to pivot for a belt change.
4. I checked the bearing and collet movement and got the same as Hoss,
ID:	46163   Click image for larger version
ID:	46164   Click image for larger version
  #123   Ban this user!
Old 11-01-2007, 02:52 PM
snowshovelbmx is on a distinguished road
Hoss I do belive you have started a very good thing here and also maybe made the guy at z-bot a little sad. As I belive spending 50 bucks or so to make your own is way better than the 500 they want for a power drawbar from LMS. I think I speak for everyone when I say thanks!
chris.
"you don't even need cnc if your handy with a torch"
  #124   Ban this user!
Old 11-01-2007, 03:34 PM
quicksilver02 is on a distinguished road
Thanks a ton for all of the info on thie Hoss! You've caused me to start gathering parts to build something similar for my SX3.
Bob - Your mods look good. One question... Is the 1/4-20 socket head bolt just to restore the height of the drawbar that you lost when you cut back the shoulder on it? I suppose you could have moved the cam down closer to the modified drawbar, but you probably already had that part built?
-Nate
  #125   Ban this user!
Old 11-01-2007, 04:29 PM
JHCHOPPERS's Avatar
JHCHOPPERS is on a distinguished road
Tool Changer Macro
Hoss,
Nice work. I am working on something simulare with an R8 collect on a BP
Can you post your tool changer macro ?
Thanks,
Joel
  #126   Ban this user!
Old 11-01-2007, 04:32 PM
hoss2006's Avatar
Nice work there Bob. good solution for the side spindle lock.
Chris,
I don't mean to cost anyone any customers, they have a fine product,
especially the complete tool changer.
But I could never afford it (or bring myself to spend that much)
I know from an email I got that they have sold at least one complete system from my mentioning them here.
I will be making an articulating tool rack later on but nothing as complex as theirs.
My new driver board came today so I can get back to it this weekend.
Have my home switches wired up just need to fine tune the mountings.
If I get the tool rack milled up, I should have it operational maybe Sunday.
Here's a light duty keyless chuck for the tool holders, good Jacobs chucks are on order.
Hoss
ID:	46177   Click image for larger version
  #127   Ban this user!
Old 11-01-2007, 04:57 PM
hoss2006's Avatar
Joel,
The genius of Mach 3 created the tool change macro, that stuff is beyond me.
You can watch the tutorial video (tool_change) here.
They have the macro for download on the Yahoo forum here.
Don't know if I could legally upload it here.
Go to Files > Macros > Toochanger Macros > M6Start.zip
Extract and replace M6Start.m1s to your Mach 3 folder, for example
C:\Mach3\macros\Mach3Mill
M6Start.m1s already exists in the original install but there isn't any code in it.
replace with the new one.
Watch the tutorial.
Hoss
  #128   Ban this user!
Old 11-01-2007, 05:01 PM
JHCHOPPERS's Avatar
Originally Posted by hoss2006 View Post
Joel,
Watch the tutorial.
Hoss
Thanks !
  #129   Ban this user!
Old 11-01-2007, 05:37 PM
Nate, the 1/4-20 was to put back the material lost
  #130   Ban this user!
Old 11-01-2007, 05:44 PM
pictorial
Here's a pictorial for the cylinder hookup.
  #131   Ban this user!
Old 11-02-2007, 01:00 AM
Micro Rotors is on a distinguished road
Hoss,
Do you have a parts list for this. GREAT JOB ... I want one!!!!!
Bill
Bill
  #132   Ban this user!
Old 11-02-2007, 07:18 AM
hoss2006's Avatar
Power Drawbar parts List
7.5 x 6.0 x .250 aluminum plate(2)
6.0 x 3.450 x .375 aluminum plate(for X2)
4.5 x 1.0 x .1875 steel plate(2)
.750 dia. x 5.0 steel rod (cam,spacers,washers)
.5 x 4.5 bolt(main pin)
.375 x 1.75 bolt (2) pins
.5 x.5 x 1.75 steel (clevis or McMaster Carr #6498K44)
7/16-20 jamb nut
3/4-16 jamb nut
1/8 cotter pins(3)
1/4-20 x .750 screws(6)
5/16-18 x .750 screws(4)
1.50"X0.75"X0.44" BIMBA
120 VAC 4 WAY 2 POSITION SINGLE SOLENOID VALVE\
Spring Washers (4)
1/8-NPT air fittings (3)
1/8-NPT plug fitting
Air line (6ft)
Compressed Air Source (100 PSI)
110 VAC switched source
Sieg X2 or other Minimill
Drawbar for BOSS 5 jeaBOSS5 Bridgeport and Hardinge Mills 3 01-12-2007 11:00 PM
Where to buy a drawbar? MrWild Bridgeport and Hardinge Mills 3 07-31-2006 06:44 PM
Automatic Drawbar Help Barry_ward General Metal Working Machines 10 06-25-2006 06:57 AM
ElectroMagnetic Drawbar? DennisCNC Mechanical Calculations/Engineering Design 17 01-09-2006 11:01 PM
Having trouble with the X2 drawbar. spoonerb Bridgeport and Hardinge Mills 2 12-19-2005 03:28 PM
