Old 09-15-2007, 07:57 PM
dneisler is on a distinguished road
CNC Fusion X3 Deluxe Kit Backlash Issues
I have a X3 with the Deluxe Kit. 425 Oz and a 640 oz on the Z. Running Geck0 203's at 54v. I am getting 120 IPM Rapid on all axis. I know I will not cut that fast.
My problem is on my X axis I have .030 backlash. It appears to be coming from the coupler between the stepper and ballscrew. As if the rubber insert in the couple is undersized. Any one have this problem or suggest a fix?
On my Y axis I have about .004 backlash. I was hoping for better, I am think it could be from the coupler too, but have not checked it.
I cut a 1" square and it came out .972 and .976 so sounds like we are off a little.
Advice?
***For full up to date details visit my blog @ www.donald-neisler.com
Donald Neisler
Old 09-15-2007, 10:06 PM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
I haven't tested mine yet.
Are your steps in the control software set to 10160?
Try cutting two opp. ends (x) of the block making sure to approach x dim from the same direction, moving the x-axis in same direction for your xdim on both sides of the block will let you know if your steps are set correctly.
Checking backlash: one way is to use edgefinder. touch off your square block and set x zero, now go to other end of block, move until you touch, take dro reading minus the diameter of the edgefinder should give you the length of the block, the deviation would be backlash + or - .001 (not best way but close)
Walking is highly over-rated
Old 09-15-2007, 10:10 PM
10160? Where did you get that?
200x10x5 = 10000
OR CNCfusion told me wrong on the screw being 5TPI
I can put my had on the lovejoy under the X axis, I can feel the gap between the inner rubber and the outer steel coupler changing, so I am think there is some play there.
Donald Neisler
Old 09-15-2007, 10:16 PM
The ball screw are metric 5mm per rev. 1 inch equals 25.4mm
10000 steps = 5 revolutions = 25mm
the extra 160 steps is the .4mm for the rest of the inch
I guess I should ask are your units set to inches?
Old 09-15-2007, 10:36 PM
Well that makes sense, I wish he would have made it more clear, he told me 5TPI. I will try that tomorrow and see if that helps.
Very please at the performance so far.
Donald Neisler
Old 09-16-2007, 01:21 PM
project5k's Avatar
project5k is on a distinguished road
see my understanding is that my cnc fusion ballscrews are 5tpi as well.. hmmm makes me wonder... the gap in the lovejoy is definately an issue, but if you cant find a mechanical fix, you could allways dial that lash into the compensation in mach 3... i would think that if you were to go to mcmaster-carr you could find some new spiders for a buck or 2...
mine are nice and tight...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 09-16-2007, 04:26 PM
Howdy guys,
I found a post over on the cncfusion forum under the thread name " Sneak Peak X3 Deluxe kit"
In a post a question was asked about the TPI. He (CNC Jedi) answered, The ballscrews are 5mm pitch.
He should have said, They're metric ballscrews at 5mm per rev.
Later on,
Jack
Old 09-16-2007, 10:37 PM
Been doing more testing and playing.
..cutting a 1" square in wood right now for testing.
.972 x .972 is what I got.
Changed(lots of playing) steps per inch to 10220
and I am getting now
.998 x 1.00
So that is better.
I can see the coupling on my X from my bench pretty good the way it is made. I attached a DTI to the table, and jogged in .001 increments.
Jogged .010 and it showed like .00992(Close enough)
Jogged back to 0, and it showed +.004
So that is .004 of backlash correct?
I did the same thing on the Y with similiar results.
I had a sherline before this, never tested its backlash, I was hoping for less, but I may be expecting to much. Does .004 sound acceptable for the deluxe setup?
Here is a few pics, not up to date but...
http://www.donald-neisler.com/index....x3-cnc-update/
Donald Neisler
Old 09-17-2007, 01:27 AM
rexstep is on a distinguished road
coupling backlash
Try wrapping teflon tape around the flexible insert- probably a single turn- and then wedge it back in to see if it fills the gap thus removing the lash
Rick L.
Old 09-17-2007, 01:44 AM
Stepper Monkey is on a distinguished road
.004 is pretty big, you should be able to cut that in half at least.
If it really is just from radial play in the couplers, you might try something other than the Lovejoy type. They can really suck sometimes. I really prefer the one-piece slitted stainless couplings. They may be pricey compared to the lovejoys, but not a big cost at all compared to the money you just spent on accurate ballscrews whose accuracy you can't use because of shoddy couplings! You could just try shimming the Lovejoys, but they will just wear again, and besides that your backlash can and will change under load as it compresses or deflects the spider - a problem you won't have with better couplings. Cheap Lovejoys are not a benefit to anyone!
  #11   Ban this user!
Old 09-17-2007, 09:13 AM
Can someone give me the direct links to some better couplings? I think I will try to shim the lovejoys right now and make sure that fixes the problem then deal with gettting some better ones.
Donald Neisler
  #12   Ban this user!
Old 09-17-2007, 10:04 AM
Donald,
www.mcmaster.com
Type 'coupler' in the search products box at the top left of the site page.
scroll down the list to, motion control couplings, misalignment couplings, metric couplings, etc..
I took a look at your pics, looks good!!!
Your power supply, is it a KL-6515 from Kelinginc? That's (KL-6515) the one I'm using and was going to hook mine up to my C11G bob like you did but, when I got my bob I noticed it needed 5v@2amps and the power supply said it was a 5v@1amp regulated or 5v@2amps unregulated. I didn't know if I could use it so, I bought the bob power supply from cnc4pc.
happy machining,
Jack
Turbocad Deluxe 9.2 mocnc TurboCAD/CAM 10 01-01-2012 12:43 AM
SNEAK PEAK: CNC Fusion X3 Deluxe kit wisp Product Announcements & Manufacturer News 17 03-10-2009 12:01 AM
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 04:35 PM
TurboCAD V10 - Deluxe Goober TurboCAD/CAM 10 04-14-2006 10:06 PM
backlash issues camfambmw5 DIY-CNC Router Table Machines 11 09-23-2003 12:33 PM
