Results 1 to 4 of 4
Thread: Sherline 5400/5410 A2Zcnc upgrade
    May 2007
    Singapore
    Hey guys, i purchased the A2ZCNC extended travel upgrades for the X and Y axis for the sherline 5400/5410 mill. I've take quite a bit of pictures of them, they are on my blog: http://simplewords.genexis.net/.
    For those who already have the upgrades, how about sharing some of the problems faced? I haven't had much time on the upgraded mill yet, but in a week's time i'll be doing quite a bit of cutting.
    Attached Thumbnails Attached Thumbnails Sherline 5400/5410 A2Zcnc upgrade-dsc01497.jpg
    my CNC Projects
    Dec 2006
    Why Y
    H-m-m-m. What am I missing or can't get my head around here?
    I very much like the idea of extended axes but it seems that on this type of setup you're limited by the distance between the column and the mill spindle so what's the benefit of the extended Y base?
    - Gerry
    May 2007
    Singapore
    you are right
    Thats why the extended 2.2" headstock is for it will increase the distant between the vertical column and the cutting bit. Now i have around 6.5" of Y axis cutting distant. I can continue to add another headstock to it to increase the cutting distant, but at the expense of have a very heavy head, which may cause it to droop.
    my CNC Projects
    Banned
    Jul 2010
    Expansion is great, just dont try to make a Boat Fly...
    The great thing about the Sherline is that it is sized right for its power. I always get great parts out of my Sherline mill and lathe. I could see the need to extend its size if you need the bigger size frequently. But I caution against a too aggressive expansion as it might loosen the machine tolerances. The upside is that you can order any parts you screw up directly from Sherline or a distributor.
    iDesign
    read http://www.novakoncnc.com to learn about my cnc nightmare
    Quote Originally Posted by genexis View Post
    you are right
  1. Replies: 14
    Last Post: 01-15-2010, 08:06 AM
  2. Sherline 5400 Motor Hot
    By greasetattoo in forum Benchtop Machines
    Last Post: 03-11-2007, 12:10 AM
  3. Sherline 5400, X2, or Taig?
    By tipschips in forum Taig Mills & Lathes
    Last Post: 08-01-2006, 09:25 PM
  4. sherline 5400 Preload nut
    By dneisler in forum Benchtop Machines
    Last Post: 11-28-2005, 12:40 PM
  5. Almost ready Sherline 5410
    By JJPPHH in forum Benchtop Machines
    Last Post: 10-23-2005, 01:15 PM
