| making double sided PCB's Hiya How do you guys go about making double sided pcb's on your mill? I can do single sided with no problems, but when i flip the board, i cannot get it to line up right. I use mach2 and eagle/pcb-gcode. i do the bottom first, then drill, then mill, flip, line up the spindle with one of the holes, switches off the steppers controllers and line mach2 up to the same hole. I then switch on the stepper drives, and move the axis to the origin onscreen, zero all axis then start the job. It lines up but is far from perfect. I know milling is not optimal for pcb's, but i would like to perfect it somewhat. Any ideas? DJH |
| Might be worth a try doing the same without switching the stepper off/on. John |
| I guess i could use the enable line on the drives? My biggest problem is getting the workpiece flat, i cannot find any spring loaded or floating heads, and im 90% sure that most of the un eveness is dues to the double sided tape as it gets air bubbles that i cannot get rid off. I need some way of holding the boards, i was thinking what about say 1/2" aluminium with an inverted keyway milled down it that the board fits into, then screw them down tight into the mdf bed? any thoughts? DJH |
| I found this in a tutorial, does it make sense to anyone? "Phase 3 was the one I was dreading the most, flipping the board over and lining it all up ready for the back. This turned out very straight forward. I had made a note of the dimensions of the 3 mounting holes. This can be done in Eagle by clicking the info button then clicking on the holes. Pcb-gcode references the back face dimensions using negative X. So all I had to do was send the mill to the hole offsets with a -ve X, jog down the z to line up with the drilled hole, then clamp the board down." what that about -ve X? DJH |
| Have you not found Olimex yet? I used to make my own pcb's but it really isn't worth the effort any more ![]() 1 piece 6.3" x 3.9" DS, pth, 2 resist, 1 legend, gold plated £17 plus shipping from Bulgaria. Okay he only cuts to rectangles but you have CNC. http://www.olimex.com/pcb/index.html |
| Well I may well use Olimex for semi large runs in the future, but I have 32 various projects at different stages of prototyping that I hope to turn into products withing the next year or so, olimex is ruled out purley by cost, lets say an avergae board costs £10 to prototype, thats £320, and thats only if each board only requires one prototype, I don't have that much faith in my use of Eagle, or even in my electronics design. I could well be looking at over £400. Wheras If I proto them myself, I find the problems, and I have only wasted a board that cost me less than £1. Plus i get to try and learn & perfect something I could not do before. I have more time than money at the moment. plus I have never gotten on with chemical etching etc, I found it very hard to get repeatable results. DJH |
| I flip the board and use 2 different sets of registration pins (and 2 different coordinate systems.) This is so I am using the same 2 edges on the copper clad as the lineup edges. http://www.electronicsam.com/images/...ostart/top.JPG sam |
Many thanks for that. I stopped doing prototypes in my ferric chloride tank when the one-off Eurocard price got below £70. £17 plus shipping???? I'm gasping. Best wishes Martin |
| I agree that Olimex is very cheap compared to other proto services Samco How do you line them up? Thats a very precise looking board Could you just go through a brief walkthrough of what you do, do you use PCb-Gcode and mach 2/3? DJH |
#10
| I agree that the fastest way to test a design is by making your own PCB prototypes, that way you send only the finished tested design to the fabrication house and can sit for a few days waiting for the boards, knowing that your design is ready to hit the market. Unfortunately, so far, I have no way to make my own pcbs, so my designs take a couple of weeks breaks between revisions to allow for the time it takes for the revised PCB designs to come back from the fab. That is the main reason I joined the CNCzone, in order to make my own PCB router someday... Kreutz. |
#11
![]() Can't afford to make quantity anything in the UK but fortunately my main product was picked up by a company in Kowloon. Less fortunately I got cloned in Taiwan but they didn't do it so well. Not for quantity, Olimex is really one off bargains. OTOH I do use them for a little interface card. I get 40+ from his standard panel plus an extra £1.65 for exceeding his 500 hole limit ![]() You have to jump through all his hoops if you want to shop, this was my last $33 panel... |
#12
| Dear Robin, Nice boards. Thank-you for the information. Best wishes, Martin |
| Double sided tape | Greolt | CNC Tooling | 25 | 09-17-2007 05:11 PM |
| Making PCB's with a small cnc mill | DennisCNC | CNCzone Club House | 4 | 12-21-2006 05:51 AM |
| Double Sided Tape? Really? | wildcat | General Metalwork Discussion | 4 | 12-03-2006 11:47 AM |
| How to get that darned sticky double sided tape off a milled pcb ? | bobJandal | General Electronics Discussion | 12 | 10-05-2006 08:53 PM |
| double sided job setups | july_favre | General Metal Working Machines | 2 | 06-14-2004 11:27 AM |
