#26
| DJH,
Alan
__________________ http://www.alansmachineworks.com |
#27
| Ahh right ok, so i get the locations of the dowels while im actually drilling them, I then write them down somewhere I then enter the G55 commands etc into the top of the Gcode, and it goes to the offset and pretends that is a temporary 0,0 home while doing that side of the board. That correct? Also i have the home switches figured out now, found somewhere that sells them with adapter plates for the taig, just hope he will ship to the Uk. Thanks DJH |
#30
| Hiya I have my home switches now What would be the easiest way to do the dowel holes? The boards I use are 100mm x 160mm, I guess I just draw it in cad? And grab the co-ordiantes of the dowels from the Gcode to setup the G55/G56 offsets? DJH |
#31
| Ok. beings as the only place I could mount the Home switches was at the limit of the machines travel, i am still struggling to drill the holes in the right place. I can do it using an offset, but then i do not know the co-ordinates of the dowels then, or perhaps I could use the machine coords in mach2? DJH |
#32
| You could draw a dxf of the work surface of your machine and the location of the dowels. Then you create gcode to drill the dowel holes at those locations. Use those coordinates (adjusted by the radius of your dowels) for your offsets. This is because you want your offsets to be the edge of the dowels not the center of the dowels. Alan
#33
| Hiya Thanks I think i got it now, Only i flipped the board the wrong way ![]() where do you get your cutting bits from? I have been using the 60 degree bits from max uk, only they are either snapping right at the end, or going blunt very quickly ![]() I may go back to V cutters. Plus the spindle belt on my Taig has frayed now ![]() DJH |
#34
| DJH, Here is a link to cutters that someone else provided. http://www.thinktink.com Also take a look at this thread. http://www.cnczone.com/forums/showthread.php?t=2078 Alan
| Double sided tape | Greolt | CNC Tooling | 25 | 09-17-2007 04:11 PM |
| Making PCB's with a small cnc mill | DennisCNC | CNCzone Club House | 4 | 12-21-2006 04:51 AM |
| Double Sided Tape? Really? | wildcat | General Metalwork Discussion | 4 | 12-03-2006 10:47 AM |
| How to get that darned sticky double sided tape off a milled pcb ? | bobJandal | General Electronics Discussion | 12 | 10-05-2006 07:53 PM |
| double sided job setups | july_favre | General Metal Working Machines | 2 | 06-14-2004 10:27 AM |
