Old 09-07-2007, 06:34 PM
spross86 is on a distinguished road
cnc shark problums?
I just got mine today and it seems that my pc is not sending the jobs to the cnc mach3 showes the job running but the cnc is not moving anyone had this problum i have it plugged into the printer port THANKS ED
Old 09-07-2007, 11:49 PM
ataxy's Avatar
ataxy is on a distinguished road
do you have the right address setup in mach3 i think that might be a cause
Old 09-12-2007, 05:22 PM
Thumbs up cnc shark problem fixed!
Thank You for your help!!
Old 10-18-2009, 02:55 PM
jason_lemay is on a distinguished road
CNCSharkPro control panel problems
Hello
New here and new to CNCSharkpro
Have a design and when i open the control panel i can jog the router into place but that is it. I cant load gcode or start job or zero it .
I am wondering if anyone has had a similar issue. I am thinking maybe there is a problem in the box such as it does not read the sd card or something.
anyway newbie and thought someone might have a suggestion.
Old 11-30-2009, 07:22 PM
wyzarddoc is on a distinguished road
Shark Startup
You need the .tap file or simular file that was generated with the correct g-code format for the shark. Then just start the control panel, load the sd card which compiles the g-code and then check zero and then run from sd card. Be sure to download the files from Nextwave to add to the Vectric software if that's the one your using
good luck and have fun the shark is a great machine out of the box
Doc
Cutty Shark I LeeWay CNC Wood Router Project Log 81 04-23-2008 09:03 AM
Shark Pro CNC? Blacksunshine DIY-CNC Router Table Machines 9 10-17-2006 11:40 AM
shark pro m!ni Commercial CNC Wood Routers 0 10-12-2006 04:41 AM
