  #13   Ban this user!
Old 09-11-2007, 03:56 AM
ataxy's Avatar
ataxy is on a distinguished road
i have been thinking about it for a while now and i came to a decision that i would go with kelling you can get stronger motor with the kelling setup for the same price
check the cnc package section
www.kelinginc.net
  #14   Ban this user!
Old 09-11-2007, 09:07 AM
Daox is on a distinguished road
I guess my concern here is the torque output of these motors at higher rpms. None of them have torque graphs. So, its hard to see how they'll perform as far as rapid travel. On the other hand, I'm not looking to run massive production so its not the biggest deal in the world. But, I would like the best I can get to start out with considering the cost is quite close. Can anyone shed some light on this?
  #15   Ban this user!
Old 09-11-2007, 09:40 AM
Eddiep is on a distinguished road
I had some small steppers (~175 oz-in)/xylotex controller/48V power supply on a 4ft x 4ft cnc plasma table with 5 tpi ball screws, and was very happy with my rapids. It was a very light weight gantry on linear bearings driven by ball screws, so there wasn't much load on the steppers, but the max speed during rapids was set to well over 100 IPM even on the heavier axis. I played a lot with stepper max speed and acceleration settings, and the motor would usually stall during the acceleration phase (once it reached the set max speed it rarely, if ever, stalled) if I got too greedy with the settings. Some larger motors would probably have helped there.
  #16   Ban this user!
Old 09-20-2007, 11:41 AM
Does anyone have a source for getting the BF-20 L in the United States? Penn Tool has not replied to my request, although I have yet to call them.
  #17   Ban this user!
Old 09-20-2007, 12:26 PM
ataxy's Avatar
if you cant get the bf20L in the states i know that garant here in canada can get you just the table for 380$ cnd or us since currently the money is about the same in value
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
  #18   Ban this user!
Old 09-20-2007, 12:36 PM
ataxy's Avatar
Originally Posted by gerryv View Post
Anyone know if there a North American source for the Vario BF20L and if not, are their machines available with single phase 60 Hz? Thanks, Gerry
I bout mine from garant in Levis, Quebec, i know at first the price seem a bit steep but if you get it from the states its going to cost you that difference in price in shipping, also you will have to wait longer to get it as it will have to go true custom, plus you will have to add in duty and taxes and the fact that if you have a problem with it the part will have as well to go true custom to get to you wich is why i decided to buy it at garant.
Just for your info penntool told me they would ship to Canada for 500$. so 900 + 500 + the duty + the taxes + the waiting time in my book = is not worth it.
  #19   Ban this user!
Old 09-20-2007, 03:20 PM
Well, I got a response from them in a timely manner today. It looks promising, and not that much more expensive either.
"There is a larger table, 700mmx180mm, available for an additional $100.00, however we did not import the #BF-200 with the larger size table.
We might be able to order the table via air freight if you are interested."
" EMCO FB-2 " (info conversion to CNC) Andrea Ganora Knee Vertical Mills 17 01-18-2011 10:48 PM
Lets Start 3-axis "khattak Mill" Khalid CNC Wood Router Project Log 46 01-14-2011 04:37 AM
Easy Q: Is 25" travel ballscrew enough for 24" bed? NC_jimbo Linear and Rotary Motion 8 03-16-2007 03:47 PM
Travel limitation on Syil X3 conversion Greolt Benchtop Machines 23 08-13-2006 06:26 AM
More Z travel please, For a Taig Mini Mill MrRage Taig Mills & Lathes 2 11-03-2005 02:46 PM
