Old 09-05-2007, 06:00 PM
lilricky2 is on a distinguished road
Swivel head for a R8 spindle on a bench top mill
Anyone heard of of a swivel head for an R8 on a smaller mill? The ones I'm fimding are too heavy and require a larger knee mill or machining center. I do quite a bit of firearm work that would be easier with a swivel at the tool rather than all the associated calculations with a tilting table. My mill is a 2hp Enco converted to cnc and the head rotates 360 degrees but doesn't tilt or swivel itself. The beast probably doesn't exist but I figure this is the place to ask.
Thanks,
Rick
Old 09-05-2007, 07:07 PM
acondit's Avatar
acondit is on a distinguished road
Rick,
Have you looked at the SX3, the RF45 or the Industrial Hobbies machines?
Alan
http://www.alansmachineworks.com
Old 09-05-2007, 09:42 PM
Not really. I was trying to avoid looking at a new mill. It's something I can't really afford right now. I am trying to make various cuts from 22.5 to 45 degrees and setting up in an angle vise and figuring each successive cut is a pain for me since I am still a novice at cnc programming. Hitting dozens of small cuts manually is a bigger pain and extremely time consuming. Angling the tool would be a very simple solution. Then again, if I ever do figure out how to write the program and set the piece up in the jig, it would be pretty simple as well.
Rick
Old 09-06-2007, 12:18 AM
acondit's Avatar
Rick,
Take a look at this thread. Dan (Hoss26) made a rotating/tilting head for his X2.
X2 cnc finished for now maybe
I would suggest reading his whole thread, but specifically look at message 279.
Alan
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-12-2009 12:11 AM
My bench-top Mill plan. KCress Benchtop Machines 1 10-31-2006 10:24 PM
bench top mil with Cat 30 or 40 spindle triump Benchtop Machines 1 10-16-2006 10:54 PM
A new bench for my mill. yukonho Benchtop Machines 5 12-29-2005 07:35 PM
Bench for a Benchtop Mill Novah Benchtop Machines 12 10-27-2005 10:50 PM
