| Help with backlash Hi again everyone. I am running into a little problem. My cnc'd mini mill has the stock leadscrews. I am using Mach 3. I am trying to cut out a circle in a peice of stock. The circle comes out looking like a circle but I can not get it to cut to the right diameter. I suspect it is a backlash problem, but am not sure. I have checked the backlash and have entered those figures into the backlash compensation. I can measure the cut out in several places and it seems to be fairly consistent in size(within .002-.004), but it always comes out about .015 smaller than it is supposed to. I have checked my drawing and it is the correct size. Any suggestions? Also what have you guys done for backlash, using the stock leadscrews and nuts? Thanks!! Walt |
| As you have removed backlash from the equasion it probably means the cutting side load on the tool is flexing the machine somewhere. If you repeat the finishing cut does that fix it? |
| Are you sure of the diameter of the cutter and Robin suggest to do one or two spring cuts. Clive |
| Backlash or motor tuning problem? How do I test for backlash? | Brian Queen | Mach Mill | 8 | 03-10-2008 04:35 PM |
| Servo idea - elimated backlash - zero backlash ! | synthetiklone | Linear and Rotary Motion | 6 | 12-06-2006 02:35 PM |
| Backlash | joedirt | Mazak, Mitsubishi, Mazatrol | 5 | 07-19-2006 11:06 AM |
| backlash | MIKE JEFFERS | Benchtop Machines | 4 | 04-22-2005 12:26 AM |
| What is backlash ? | ynneb | FAQ of CNC Machine building | 0 | 08-16-2004 08:27 PM |
