  #13
Old 08-24-2007, 11:25 PM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
Hey Steve,
Thanks for the referral to Discount Machine Shop.
  #14   Ban this user!
Old 08-24-2007, 11:40 PM
It is close to impossible to consistently get a good finish on aluminum without some coolant or lubricant. One cheap and easily obtainable lubricant you can use is automatic transmission fluid; just brush it on down the path you will cut, even a small amount will prevent the chip welding to the tool.
  #15   Ban this user!
Old 08-25-2007, 11:51 AM
scubasteve_911 is on a distinguished road
Originally Posted by txcowdog View Post
Hey Steve,
No Problems! When you're a poor engineering student like myself, you just have a nack for smelling out the best values
Steve
P.S.- Discount Machine Shop is actually a company called Shars at www.shars.com , but they offer pretty much everything that is listed online at Shars at a discounted price on Ebay. To place an order, I give ebay links in an ebay with quantities. If there is something in the catalog that isn't on ebay, I can order it this way from them via a part number. I have been very happy with their stuff and won't go anywhere else. I ordered a 31$ screwless vice and I was astounded by its quality.. Maybe because I am new to machining, but I couldn't believe that I cannot see the seam where the vice closes, even under very good lighting...
  #16   Ban this user!
Old 09-19-2007, 02:33 PM
bnocturnal is on a distinguished road
Originally Posted by conlimon View Post
hey all -
i'm a newbie with my Taig 2019 er16 setup from Deepgroove1,
Hello,
I was wondering if this is the setup you purchased: http://cgi.ebay.com/ws/eBayISAPI.dll...ksid=p3907.m29
And are you happy with it? I saw one other post on here that was not happy with Deepgroove1, but they seem to have a really good price on the Taig.
Thanks,
Dave
  #17   Ban this user!
Old 09-19-2007, 07:20 PM
fredhh47 is on a distinguished road
Here is a trick I use when I need to lubricate the cutter on my milling machine. It can get a little messy, but works well enough that I haven't invested in a dedicated mist sprayer. Put an acid brush in a can of dark cutting oil and have it sitting near your machine. When the cutter gets into the cut, take the oiled-up brush in one hand and an air hose in the other. Put the bristles of the brush into the air stream while aiming the air stream at the cutter. Voila', a do-it-yourself mist spray. This really works very well when flycutting or face milling, but also is fine for slot milling. If this fails, buy a cheap mist spray unit and some water-soluble coolant and mix it very thin. I use about one to two ounces of WS concentrate to a gallon of SOFT or de-ionized water (like for steam irons). My hard water makes a goopy mess and the crap doesn't dispense well. P.S. when using the dark oil, be warned that it smokes and stinks. Open a window or a door for ventilation.
Fred
machining Aluminum for the first time. carguy327 General Metalwork Discussion 10 10-26-2006 07:27 PM
RFQ for 120QTY 5/8" Round Stock Standoffs 6061 Aluminum mpstech Employment Opportunity 6 09-20-2006 03:02 PM
Parts RFQ Machining 6061 hoju1301 Employment Opportunity 6 07-11-2006 06:07 PM
Help - Cutting Aluminum 6061 dfranks DIY-CNC Router Table Machines 50 11-18-2005 03:32 PM
Turning Aluminum 6061-T6 Machine1 Hard and High Speed Machining 3 09-11-2003 12:04 PM
