Old 08-21-2007, 11:31 PM
44 Echo is on a distinguished road
TMC-1000 Troubleshooting Help
Having some problem with my TMC-1000 CNC mill. All three motors power lock on start up, however, no motion from controller. Is there anyway to isolate this issue, before I incur the expense of sending the controller back to Intellik? Thanks.
Old 10-07-2008, 04:37 PM
wongstein is on a distinguished road
Hi Jerry,
I set up my TMC1000 to try out the DOS software. Here's a picture of the manual mode screen. Is this what you're using? If so, do the numbers in the upper right still increment and decrement when you use the jog keys? Also, does any sound come from the steppers when you jog?
Anthony
Old 10-07-2008, 05:03 PM
Anthony:
Yes, my screen looks like that, and the DRO increments when I use the arrow keys. The stepper motors energize, but nothing moves. When the motors are energized, the ballscrews are locked. When the power is off, I can turn the leadscrews.
Jerry
RS232 Troubleshooting gar Haas Mills 10 08-02-2007 07:48 AM
troubleshooting buddy EvanB Commercial CNC Wood Routers 0 04-03-2007 09:28 AM
CNC Code troubleshooting sinnfeinan Mach Software (ArtSoft software) 3 11-13-2006 08:05 AM
Koike D10 Troubleshooting kevin@work CNC Plasma and Waterjet Machines 3 09-23-2005 04:37 PM
Who's The Troubleshooting Expert? freak_brain Gecko Drives 10 04-09-2005 10:43 PM
