Old 08-20-2007, 11:09 PM
dfurlano is on a distinguished road
MT2 er32 Collet Holder
Is there anywhere in the US where you can buy a MT2 er32 collet holder?
I cannot believe that no one sells these.
Dan
Old 08-21-2007, 04:37 AM
philbur is on a distinguished road
I think ER32 is bigger than would be appropriate for an MT2 taper. I think MT2 normally only goes up to ER25 then MT3 takes over.
You may be lucky and find one but I wouldn't hold my breath.
Phil
Dan
Old 08-21-2007, 06:15 AM
Greolt is on a distinguished road
Have a look at this ebay item number. 110160580517
Greg
Old 08-21-2007, 07:09 AM
There you go, I new somebody would prove different. However if you look the MT2 shank is somewhat feeble compare to the holder itself.
The thick end of a MT2 is 17.8 mm and the maximum holding diameter for an ER32 collet is 20mm. The tool bit or work piece is going to be stiffer than the holder, by a considerable margin. However as long as it is only lightly load it should be OK I guess. I assume this is why it is not very common to but a MT 2 shank on an ER32 collet holder, at least not for metalworking. It may be different in the woodworking world.
Regards
Phil
Greg
Old 08-21-2007, 07:15 AM
Yeah I agree phil. I have a MT3 in my X3 and use ER25 collets. Seems to me to be a better balance.
Can't imagine needing ER32 in such a small machine.
Greg
Old 08-21-2007, 04:50 PM
Yeah, I know about this guy but I wanted it asap so I was hoping for a US supplier which it seems there are none.
Greg
R8 Collet Holder Tool Setter Chrisjh Syil Products 12 08-06-2007 09:44 PM
7x10 headstock collet holder? Tim Wiltse Mini Lathe 2 04-23-2007 08:43 PM
R8 Collets and ER32 Collet Chucks wildcat General Metal Working Machines 1 02-22-2007 05:19 PM
Expected runout from an ER32 collet chuck buckie555 General Metal Working Machines 10 04-01-2006 08:32 AM
Question on ER32 collets Bubba General Metalwork Discussion 5 01-10-2005 05:49 PM
