  #181   Ban this user!
Old 01-21-2012, 11:30 PM
CNCfun&games is on a distinguished road
More Cross Slide activity
The Cross Slide Modification is a continuation of the work depicted on pages 4, 7 & 8
of this thread.
Both of the Timing Belt pulleys needed some modification before they could be installed.
The Lead Screw pulley had to be reamed from the stock .375 Dia. to 10 MM.The Motor pulley had to be drilled and tapped #8-32 in the cog area because the motor shaft was to short for this particular configuration.
all the parts were then collected for assembly.
Name:	Ream to 10mm.jpg‎
ID:	150783   Click image for larger version
Name:	Ready for Assembly.jpg‎
  #182   Ban this user!
Old 01-22-2012, 09:18 AM
Rodm1954 is on a distinguished road
CNCfun&games,
Good to see this thread active again and look forward to seeing more of your builds.
cheers,
Rod
Perth, Western Australia
  #183   Ban this user!
Old 02-13-2012, 12:56 AM
Rod M: Thanks for visiting this thread. I learn a lot from your builds!
Continuing the Assembly of the “ULTRA” Cross Slide.
AS illustrated earlier, this Design utilizes Linear Rails on both the X and Y axis'.
However; The Lead Screws, Nuts and associated Hardware for the X axis are common
to both the Ultra and Standard Models. (Standard Model uses the stock Dovetail Slides)
The Y axis Kit is also common to both Models as are the base modifications which support
the Y axis lead screw & bearings. A flat CRS Plate is used on the ULTRA model in place of the saddle which is supplied on the Standard Unit.
W. Smith Mission Viejo, CA.
Name:	Common Lead Screw Parts -X-Axis- p01.jpg‎
ID:	152629   Click image for larger version
Name:	Common Cross Slide Parts- Y-Axis-02.jpg‎
ID:	152630   Click image for larger version
Name:	Ultra Cross Slide Assy - 01.jpg‎
ID:	152631   Click image for larger version
Name:	Ultra Cross Slide Assy - 02.jpg‎
  #184   Ban this user!
Old 03-03-2012, 02:58 PM
Z axis improvements!?
Assembly and critical evaluation of the 3 Bridge Mill prototypes has resumed.
Efforts to decrease the profile of the all steel Z axis will result in increased travel of the Y axis and overall simplification and reduced machining time of Z axis parts. The redesign will be based on concepts which were used on the Aluminum Router Z axis.
W. Smith, Mission Viejo, CA
Name:	Base Plate Mod.-03.jpg‎
ID:	154264   Click image for larger version
Name:	Bridge Mill -CRS-02.jpg‎
ID:	154265   Click image for larger version
Name:	Bridge Mill -13.jpg‎
ID:	154266   Click image for larger version
Name:	Base Plate Mod.-01.jpg‎
Name:	Base Plate Mod.-02.jpg‎
  #185   Ban this user!
Old 03-05-2012, 02:05 AM
wizard is on a distinguished road
You have some really nice builds going there.
I'm just letting you know that I follow everyone of your postings as I find the project you are engaged in most interesting. I wonder how you find the time!
  #186   Ban this user!
Old 03-14-2012, 11:12 PM
A little R & R with a H1 3D Printer Kit
Z axis Modification;
the first two 1018 parts are in work. The Drawings were updated and are enclosed.
Next the Z mod. Mounting Plate & Z mod. Mounting Block will be machined.&
the drawings posted.
Wizard:
so many interests ….so little time....I'm off on a detour again!
We recently purchased an H1 Hardware kit & an extra “Steve's Extruder from SeeMeCNC.com
It is a very nice Tinker Toy style Machine. Lots of fine injection molded parts, threaded rods and nuts & bolts galore.
Operating the H1 should give us a good baseline for a process which is relatively new to us.
After that we will proceed on a sturdy Aluminum Bridge configured “3D Printer Design.”
for the present we will continue working on our current projects.
Name:	Motor Mount Plate Mod.-01.jpg‎
ID:	155063   Click image for larger version
Name:	Motor Mtg Plate-04.jpg‎
ID:	155064   Click image for larger version
Name:	Z AXIS BASE PLATE (copy).jpg‎
ID:	155065   Click image for larger version
Name:	Part1v2 (another copy).jpg‎
  #187   Ban this user!
Old 03-15-2012, 09:25 AM
allesg is on a distinguished road
Really glad to see this thread going again!
  #188   Ban this user!
Old 03-15-2012, 09:41 AM
HorridHenry is on a distinguished road
Nice work so far.
Does this do Chicken Masala?
A benchtop cnc lathe build S_J_H Vertical Mill, Lathe Project Log 291 06-10-2011 01:02 AM
Plasma Table Build Log Including Free Plans Link, & Pictures by Weldtutor Weldtutor Plasma, EDM and other similar machine Project Log 426 04-06-2011 09:26 PM
Starting knee-mill retrofit. Your input appreciated. jamma General Metal Working Machines 2 03-01-2007 10:41 AM
CNC Mill and CNC Lathe offered. Aluminum and Gray Iron Castings maquiza Employment Opportunity 0 12-31-2005 10:37 AM
Anyone mill templates for castings? studysession General Jewelry Design Software 5 12-05-2005 03:08 PM
