Old 08-18-2007, 12:54 AM
iamscottym is on a distinguished road
Turning 2" OD Delrin on an X3- power issues?
I am looking to purchase a small mill, because my college's machine shops are only open 9-5 and I find myself needing more time to work. Anyhow, I'm planning on getting an X3, because it's about the biggest machine I'll be able to move around. I would also like to get a lathe, but getting an X3 cnc'ed with cnc fusion's ground ball screw kit, plus geckos, Mach 3 and a cam package will pretty much tap me out for the time being.
Most of my work revolves around a guided rocket I'm building, and so I need to be able to turn nozzles. I'll be using 2" OD delrin in a step collet. Would anyone anticipate power issues with an X3? If so, how powerful of a motor would you suggest? I'm planning on adding a belt drive to get a little more rpm range anyhow, so I'm considering a BLDC motor. I've been seeing some really powerful outrunners lately that I'd love to play with.
Thanks,
iamscottym
Old 08-23-2007, 01:19 PM
thackman is on a distinguished road
I'm sorry but I'm abit confused. If I understand your post you are asking if an X3 has enough power to turn 2" OD delrin but the X3 is a mill not a lathe and this is the benchtop mill forum. Since you have been around a machine shop I'm guessing that my confusion is simply because of how the sentences and thoughts run into each other.
You indicated that your first purchase would be a mill and a lathe later when you could afford it. So are you asking if it's possible to somehow chuck the 2" Delrin stock in the mill spindle and use it like a lathe or are you asking which lathe should you should consider purchasing?
You can perform many lathe ops on a mill if your stock is very short, can be securely held in a collet somehow, and is of a reasonably small diameter. I've seen some pretty amazing videos of a cnc mill performing successive lathe operations on a bushing just like a cnc lathe would but 2" stock is a bit larger than I would feel comfortable starting with. I think it is possible but I would start with a 3/4 or 1" dia. piece and work up from there. If you can clarify how you intended to hold the stock it might clarify some things.
I'm not a rocket builder but I'm surprised to hear of delrin being used as a nozzle. Usually those are either metal, carbon or ceramic. I'm assuming that the Delrin was for the nozzle and not the body from the preceding sentence.
Old 08-23-2007, 02:48 PM
Yes, I am aware the X3 is a mill, not a lathe. Most of the work I need to do requires a mill, but I also need to be able to turn a few nozzles and won't be able to afford a lathe at the same time. Given the X3's specs, it has enough travel to be able to turn the nozzles, but I'm not sure it has enough power.
Assuming I upgraded the motor, would an X3 otherwise handle the extra power (say 2HP)?
The nozzles are short enough that I just use a collet on a Hardinge lathe, so work holding is not an issue.
(These are not pyro rockets, they use compressed gas and water- the FAA wouldn't like me putting a guidance system on a pyro rocket)
Old 08-23-2007, 03:45 PM
Andre' B is on a distinguished road
You can always mill the nozzels as a 3D surface.
Or you can put a rotary table on the mill to turn the part for working on really large diameter stuff.
I finished the OD on some 24 inch diameter wooden wheels using an 8" rotary on an RF30.
Old 08-23-2007, 05:40 PM
Oldmanandhistoy is on a distinguished road
Thanks,
iamscottym
The simple answer to your question is imho yes there will be enough power in a 600+ Watts spindle. I have turned 2” Delrin on a mini lathe with a 350W motor without problems. As I am sure you are aware depths of cut will need taking into account.
John
Old 08-24-2007, 08:43 PM
gmfoster is on a distinguished road
Actually turning on a mill isn't all that hard. Just mount your lathe tool in a holder on the the table and have a go..
Works quite well for short stubby parts.
Garry
Turning Delrin Rod Spam16v Glass, Plastic and Stone 11 08-19-2007 10:50 AM
RFQ 5/16" black delrin - laser or waterjet cut - fast turnaround... InspirationTool Employment Opportunity 1 07-11-2007 02:51 PM
Turning Delrin Crashmaster General Metalwork Discussion 3 07-10-2007 03:25 PM
Turning smaller diameter delrin? conceptmachinin General Material Machining Solutions 29 03-08-2007 03:02 PM
Turning Delrin CNCadmin Glass, Plastic and Stone 3 11-15-2006 06:32 AM
