Old 08-15-2007, 09:11 AM
rodzilla is on a distinguished road
Round column mill
I have a round column HF Mill 33686 i believe is the part number i is the big green one i am interested in putting a motor from my treadmill on this to power the spindle as i see people out there doing this very thing to what degree of success i din't know as most of these threads do not say. Which brings me o my question(s). After doing this will i be able to machine steel as most of my machining is steel with the occasional alum parts. Also seeing that i have a treadmill to cannibalise can i use the motor and controls and just build a different housing for the controls and electronics or will i have to get a different set of controls to run the motor. Please any help on this subject would be greatly appreciated as i don't want to take apart a good running treadmill if it is not going to work.
Old 08-15-2007, 01:35 PM
Wow does anybody want to answer to this post Please!!!!
Old 08-15-2007, 04:56 PM
acondit's Avatar
acondit is on a distinguished road
Rodzilla,
Why do you want to replace the existing motor? It may be more powerful than a treadmill motor (depends). Sorry I can't help with the treadmill controls question.
I put a DC motor on my 9x20 lathe and I bought a controller on ebay. It is more powerful than the motor that came on it originally (3/4 hp replaced by 1 1/2 hp). However, my round column mill has a 2 hp AC motor on it and I would only consider replacing it with a DC motor if it went bad. To find a good 2 1/2 to 3 hp DC motor with continuous rating would not be cheap, not to mention that I would have to rewire for 220v for the mill. It currently runs on 110v with a 20 amp breaker and if I try to run anything else on that circuit at the same time it trips the breaker.
Alan
http://www.alansmachineworks.com
Old 08-15-2007, 05:34 PM
Robin Hewitt is on a distinguished road
I have much the same, the start up current sometimes throws the RCB when I turn it on. I reckon it has to be when my turn on coincides with a peak on the mains cycle.
I'm replacing the motor relay with a fat triac and an MOC3041 that switches as the mains crosses zero volts. See if that fixes it
Old 08-15-2007, 09:00 PM
I am not going to do the motor change if i will lose to much power i just think the vriable speed would be alot better and faster than changing the belts. I just wanted some opinions from some people who have more experience with this stuff as i am pretty new to this stuff. I also don't want to convert to 3 Phase i have wenough problems figuring out single phase stuff throw 2 more phases in there and my head will explode.
Round Column Mill Conversion. Willyb Benchtop Machines 23 08-25-2007 04:53 PM
converting a round column Paul in OK Benchtop Machines 3 10-27-2006 05:15 PM
Help! Why Round Column Mills not fit to convert to CNC? szcharle Benchtop Machines 17 08-01-2006 07:03 PM
Round column mill SCROMAL General Metalwork Discussion 1 06-18-2006 01:23 PM
HARBOR FREIGHT small round column mill to a square column conversion. motomitch1 Vertical Mill, Lathe Project Log 25 12-01-2005 11:24 AM
