  #37
Old 08-12-2007, 02:03 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
http://www.toolstation.com/images/li...bbig/50532.jpg
Old 08-12-2007, 04:40 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Originally Posted by NC Cams View Post
Square holes can be rather sexy
I am so confused be this statement. What is is pertaining too???
Anyway,
EDM, Shaper, or a small drilled hole in the corner and cleaned out with an end mill. Granted it won't be a sharp inside corner, but the radius will be as small as the drill you use.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
  #39   Ban this user!
Old 08-12-2007, 05:15 PM
Astroguy is on a distinguished road
Originally Posted by cnczoner View Post
Astroguy, I just picked up one of these little squares yesterday and it has the inside-corner cut in as Al is explaining. Click on this picture for a larger view and look at the inside corner... http://woodcraft.com/family.aspx?familyid=20077
Cheers,
-Neil.
Thanks!
  #40   Ban this user!
Old 08-12-2007, 10:23 PM
bigbunny5's Avatar
bigbunny5 is on a distinguished road
Originally Posted by epineh View Post
That reminds me, being in the electrical game, we always used to keep a "cable stretcher" somewhere in the workshop, just in case, though the apprentices always had trouble finding it... hard to get good help.
Russell.
I got an 8' board stretcher here in the shop, I'm relay want to save up for a 12' one next
An idea that is not dangerous is unworthy of being called an idea at all, and Consistency is the last refuge of the unimaginative.
  #41   Ban this user!
Old 08-14-2007, 03:05 PM
peter@slater is on a distinguished road
Square Hole Broaching
A rotary broaching tool holder should fit on your CNC machine. To make the square hole using this tool, first pre-drill a hole to the flat-to-flat dimension, then use a broach of the same dimension to take out the square corners. The best way to understand how this works is to watch the video.
http://www.slatertools.com/video.htm
  #42   Ban this user!
Old 08-15-2007, 08:11 PM
S_J_H is on a distinguished road
wow, I watched the video. Pretty darn impressive!
Steve
The wiring inside a control box... MrWild General Electronics Discussion 2 06-02-2007 12:13 PM
Diameter of inside cut, too small SVM General CAM Discussion 16 06-19-2006 09:17 AM
inside turning Nine General Metalwork Discussion 3 02-15-2005 10:33 PM
Can someone help me with gcode or cad/cam(3dfigures inside) HawainPand Employment Opportunity 15 09-11-2004 10:34 AM
What's inside this box? Bloy2004 General Electronics Discussion 3 04-07-2004 09:07 PM
