Page 1 of 4 1234 LastLast
Results 1 to 12 of 42
Thread: How do you cut square inside coners?
    May 2007
    Ok, I am haveing fun learning my new machine a CNC Taig. But now I need to start making parts. How do you machine a square inside coner?
    Dec 2003
    One method, which depends on whether you can tolerate it cosmetically, is to use a small diameter tool for the final finish on the outside of the pocket, and when the corners are reached the tool moves out a small distance at 45°, just enough to take out the normal radius that is left.
    This depends alot on your application.
    Al
    May 2007
    Quote Originally Posted by Al_The_Man View Post
    Al
    I`m not sure I understand how that works?
    Dec 2003
    IOW if you used, say a 1/8" endmill to get the corners as close as possible to a right angle, then move outward from the corner at 45°, this causes a small semicircle out from the corner, if you were making a pocket for a rectangular item to fit into, this would relieve it enough for it to drop into, this is one method I use to, but maybe not pretty.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Quote Originally Posted by Astroguy View Post
    You CAN'T
    Al's method is a workaround to allow a square part to fit through the aperture.
    Square holes are made by broaching, EDM or filing.
    www.integratedmechanical.ca
    Registered acondit's Avatar
    Apr 2005
    If you mill around the inside of the square with a 2" diameter tool, it leaves a 1" radius in the corner. The distance from the edge of the tool to the corner of the rectangle is the ((square root of (1^2 +1^2 )) minus 1) or the square root of 2 - 1 which is approximately 0.414". So when the tool is tangent with both side of the corner, you could move on a 45° towards the corner to remove the remaining material from the corner. Of course the smaller the tool that is used the less the deviation from square.
    Attached Thumbnails Attached Thumbnails How do you cut square inside coners?-cornercutting.jpg
    May 2007
    Duh, OK now I see. Thanks guys, I have learned so much here.
    Dec 2005
    U.S.A.
    We call those corners "mouse ears". They work fine in the mold business.
    Mar 2007
    UK
    ...or, you could use a square hole drill, I kid you not
    http://www.integerspin.co.uk/polygon.htm
    Registered Bowman's Avatar
    Sep 2004
    Darebee is right squared corners are made with broaching cutters, EDM's or filing.
    You could try to cut the pocket and then come back with a smaller diameter cutter to lessen the corner radius but it will still require broaching or filing to get them truely square. If you can get the radius as small as possible first it lessens the amount of filing needed to square things up.
    Bowman
    Apr 2005
    Astroguy,
    I guess the real question now is ,"Do you really need square corners, or do you need a hole that something square will fit into?
    Alan
    Registered M100's Avatar
    Oct 2006
    UK
    Maybe he just needs a deliberate stress raiser
  • Page 1 of 4 1234 LastLast
    1. The wiring inside a control box...
      By MrWild in forum General Electronics Discussion
      Last Post: 06-02-2007, 01:13 PM
    2. Diameter of inside cut, too small
      By SVM in forum General CAM Discussion
      Last Post: 06-19-2006, 10:17 AM
    3. inside turning
      By Nine in forum General Metalwork Discussion
      Last Post: 02-15-2005, 11:33 PM
    4. Can someone help me with gcode or cad/cam(3dfigures inside)
      By HawainPand in forum Employment Opportunity
      Last Post: 09-11-2004, 11:34 AM
    5. What's inside this box?
      By Bloy2004 in forum General Electronics Discussion
      Last Post: 04-07-2004, 10:07 PM
