| Thanks HO, I also found the MACH 3 files for Sherline... http://www.tabletopmachineshop.com/f...p?shop=1&cat=1 I will start there and use your instructions to fine tune. THanks |
| I think for the sherline, it has 20 tpi screws like my maxnc. 32,000 (in microstepping) start around 25 velicity and 1.5 acell. Hen tuning the motors I have found that if you set the accell rates very low. 0.8 ect and jog the axis back and forth its really easy to see if your going to stall the motor. For the most part if you can set you speed (say around 30 to 35 IPM) and successfully jog with the accell very very low then it should be a fine speed. Also a note. Things change a bit when all axis are running. So write you a test g-code that will run all 4 axis at once. Make the code long with lots of movements ect. When you find the higest speed the machine can run and be stable (Extensive testing required) back the speeds down about 20 % and save settings. |
| Need Mach 2 configuration help for Sherline 5410 | wilit | Mach Mill | 14 | 01-15-2010 07:06 AM |
| Settup problems wih Mach 3.... | Green0 | Syil Products | 7 | 04-12-2009 02:50 AM |
| Problems with demo of Mach | tt_raptor_90 | Mach Software (ArtSoft software) | 5 | 05-24-2006 10:31 AM |
| Mach 2, 1,7GHz pentium M problems | fantasy2 | Machines running Mach Software | 12 | 04-10-2006 07:03 AM |
| MACH 2 configuration for Xylotex Board | ngr1 | Mach Software (ArtSoft software) | 5 | 08-13-2004 01:03 AM |
