I've been looking for a X3 belt drive conversion for some time because I would like a broader rpm range for this machine. Something similar to the X2 would be preferable. I'm away from home for about another month so designing the conversion myself before school starts up again would be a bit of a problem. Also, I am not sure how to find the way to figure out what the proper size of pulleys I would need and how I would go about making them. The biggest problem wouldnt be the pulleys, I know how to machine those, it would be the keyways which are a mistery to me. And yes, I have seen the "ArcEuroTrade.Com" pdf file but I would like to get rid of the gears so that I can expand the rpm range and quite the machine. Any suggestions. Thx |
The Keyway you need to buy a "Broach" they run around $45.00 for both part. Smitty |
| Well, after the less than stellar response to this thread I have decided to make the thing myself. However, before I can start to purchase materials I need to know the pulley diameters. I intend to design and mount the motor just like this gentleman has done on his x3: http://homepage3.nifty.com/rockhill/index.htm. I dont intend to replace the motor so what I need to know is, how fast is the motor turning at max rpm. I cant find the info on the motor itself nor in the manual pages. So help with this would be appreciated. |
| http://www.grizzly.com/products/G0463 |
Jordan, Your right, unfortunatly I talk/type without fully thinking. It could have been 1/3 reducer also. LOL Smitty |
| Look at the last pdf on this page, its a belt drive mod for the X3, with pulley sizes etc. http://www.arceurotrade.co.uk/projec...CNC/index.html |
#10
The stock motor runs about 4000rpm, I am thinking of a 3 pulley direct drive and bypassing the gears completely. Low............ 8:1 Med............ 2:1 High ........... 1:1.25 This gives 50-500 in low 200-2000 in med 500-5000 in high |
#11
| i have to wonder what the life expectency of the bearings would be at these increased speeds...
__________________ Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino. |
#12
| 5000 RPM is right at the upper limit for the OEM X3 spindle bearings. However most people are not going to be running the machine 40 hrs/wk like a business would so even at these speeds they should get many years of service. Replacement with a higher quality aftermarket bearings would let you run 7000 RPM all day long if the bearing bores and shafts have the exact press fits Keep in mind this machine was made in a factory in China that has only 1 CNC tool, a FADAL mill. All these shaft parts are run on manual equipment. So YMMV, and good luck. |
| Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? | pfeist | General Metal Working Machines | 11 | 02-13-2012 02:12 AM |
| X1 Belt Drive? | Tag1260 | Benchtop Machines | 12 | 08-31-2007 05:38 PM |
| Belt drive conversion for X3? | phantomcow2 | Benchtop Machines | 2 | 07-16-2007 06:31 PM |
| Belt Drive Spindle Possible? | Bird_E | Industrial Hobbies (Support forum) | 24 | 11-26-2006 08:44 AM |
| Timing belt drive | jdholbrook | Linear and Rotary Motion | 1 | 04-29-2006 03:26 AM |
