Old 07-09-2007, 09:02 PM
gunner312 is on a distinguished road
Re-fitting a mill
I just bought an older Prolight 1000 Desktop CNC mill. Unfortunately the contol has been taken for repairs to another machine. So I have bought the following:
3 Kelig 425 oz-in steppers. (I already fitted them to the frame axis)
3 Gecko 203V drivers.
and a CNC4PC C11G breakout board.
I have a computer and etc, to use with it.
I have a power supply (54V 7.2A power supply).
I think the DC spindle motor control is fried too. (Cant get current to go through it) (Minarik PCM2100A) a new one is available from the Manufacturer if so. Not a real problem.
The spindle motor is pretty much toasted so I will have to replace it or have this one re-wound.
I've replaced the spindle bearings on the quill.
I need help in getting this turkey (in it's present condition) wired up and running.
I'm a pretty good machinist if I say so myself but not a very good electrician.
Help would be appreciated. I am in Washington state near Bremerton.
Thanx.
Jim Wright
360-275-8550
Old 07-11-2007, 09:31 AM
acondit's Avatar
acondit is on a distinguished road
Jim,
If I recall correctly, Dan Mauch lives near Seattle. You might contact him through his website http://www.camtronics-cnc.com
Dan builds controller units using Geckos.
I think you can find a schematic for wiring the Geckos either on the Geckodrive website or on the Gecko yahoo group.
http://finance.groups.yahoo.com/group/geckodrive
Sometimes you can pick up Minarik controls through the "SurplusCenter". http://www.surpluscenter.com/
Alan
http://www.alansmachineworks.com
M6 x 1.0mm grease fitting N4NV Mechanical Calculations/Engineering Design 5 03-31-2006 04:03 PM
RFQ: Lathe Job - Manometer Fitting lerman Employment Opportunity 1 01-24-2006 04:54 PM
Retro fitting new2this Industrial Hobbies (Support forum) 1 01-21-2006 06:21 PM
Hose-fitting supplier - please help DrStein99 Mechanical Calculations/Engineering Design 23 11-28-2005 11:20 AM
cnc fitting a bridgeport MBG Bridgeport and Hardinge Mills 5 09-26-2005 04:25 PM
