Hi all Wondering what spindle speed and feed rate people are using to mill hdpe. My top speed is 4600 rpm on my cnc'd mini mill and I have some hdpe parts to cut, I played around with it some last night but not happy with results. Any help would be great!! Walt |
| Well it could be High Density PolyEthylene. ![]() If it's poly then you can run max spindle rpm. Adjust feedrate to where the cutting looks its best... just experiment with the value for a particular cut. The main thing is to keep a blast of cool air blowing at the cutter. More is better. Note: If you don't keep the PE chips as cool as possible they will get too sticky and then it melts into a glob. (Glob = technical term for "blob") Suggestion: Keep a ShopVac hose sucking up the chip stream helps keep the cutter visible -so you can see whats happening. Good luck, Pres Last edited by Pres; 07-10-2007 at 02:10 AM. Reason: spelling |
| Speeds & Feeds | hector herrera | Mastercam | 1 | 02-20-2007 02:21 PM |
| feeds and speeds | JpBinc | General Metalwork Discussion | 4 | 10-03-2006 12:48 AM |
| feeds and speeds | rchprks | General Metalwork Discussion | 2 | 07-17-2006 06:48 PM |
| Speeds and feeds | Hack | General Metalwork Discussion | 2 | 10-15-2005 10:47 AM |
| feeds and speeds | lito | General Metalwork Discussion | 4 | 03-14-2005 07:58 AM |
