What especially you would like to know?
If you have a vise like that:
http://www.glacern.com/gsv_440
Copy the dimensions of the original jaws,
maybe make them little higher in Z- direction.
Machine those from thick aluminium, bolt them to your
vise, and then before you machine your parts shape to your
soft jaws: put something thin between your jaws before
you tighten your vise. It could be something like 0.5mm (~0.02 inches)
thick steel ruler, strip of thin sheet metal or something like
that. That will put your jaws apart something like 0.4-1mm when you
tighten your vise.
Then machine your parts shape to your soft jaws. Usually it's some pocket toolpath if you use
cam. After that, you will
have your parts shape at your soft jaws. Open the vise, throw
that piece of thin sheet metal away, and there you have
your parts shape at your soft jaws, and also enough gap
between the jaws so that you can tighten your parts well.
I hope that explanation makes some sense. I would have put couple
pictures, but I forgot my camera to my workshop.
Another possibility is to make thinner soft jaws, which lower
part will fit tightly to the slot at the center of the vise.
>you seem to have a set for every part you make?
I would rather not make soft jaws all the time, but
it just seems that all the parts I make will require them
