Old 06-18-2007, 03:13 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
Looking for X2 spindle housing bolt hole dimensions
Hey Gang,
Was wondering if anyone could give me the bolt hole locations and hole diameters for the spindle housing.
Here's a pic of the replacement part from LMS.
Need to know the center to center for A and B and the Diameter for C.
I'll have to tear into mine soon enough but would like to have the parts ready to go instead of putting it back together to finish the 4 holes in the parts.
Thanks alot Hoss
Name:	spindle housing dimensions question.jpg‎
Old 06-18-2007, 07:41 PM
digits is on a distinguished road
Originally Posted by hoss2006 View Post
Hey Gang,
Thanks alot Hoss
Hi Hoss - I feel a bit nervous posting these numbers incase my measurements are out and I cause you to stuff up a part! Anyway, I have recently made a mounting plate for my X-2 head : I had A=88mm, B=44mm and C=M8 (i.e. 8mm) .
It seems to fit fine for me, but I have used 9mm diameter holes as I am just bolting M8's through to the tapped holes on my X-2 head.
I hope that helps, but if you use my numbers, you do so at your own risk!
Old 06-18-2007, 08:09 PM
Rodm1954 is on a distinguished road
Hi Hoss
Measuring the bolt hole pattern on the head (the mating part to the one pictured) I get A at 88mm, B at 45mm and the thread is M8.
cheers,
Rod
cheers,
Rod
Perth, Western Australia
Old 06-18-2007, 08:33 PM
skmetal7 is on a distinguished road
another super secret x2 add on, huh?
hmm no dowel pins? weird. i wonder how they square it the spindle, and keep it square.
Old 06-19-2007, 10:12 AM
hoss2006's Avatar
Thanks guys, really appreciate it.
Makes life easier.
Super secret X2 project can proceed now.
Those dimensions are what I was hoping, now i don't have to redraw the plans.
Later Hoss
bolt hole circle sanddrag Employment Opportunity 5 01-23-2007 06:52 AM
powder coating a spindle housing? DennisCNC Mechanical Calculations/Engineering Design 4 01-16-2007 10:08 AM
Bolt hole pattern with only a drill press sanddrag General Metalwork Discussion 7 05-04-2006 01:41 PM
Bolt hole spacing on a flange Bill Wann Autodesk Software (Autocad, Inventor etc) 4 03-15-2006 07:11 AM
Drilling Bolt Hole Patterns TURNER G-Code Programing 17 01-02-2006 06:49 PM
