Wondering if someone could either give some quick advice here or hop on AIM to talk.
I am heading to Home Depot to get wire to wire up my IMService servos, servo drives and PMDX-122 board. Wondering the following:
What gauge wire is needed to go from the power supply to the servo drives?
What gauge wire is needed to go from the PMDX board to the invividual servo drives?
If anyone can answer those real quick, I am making a trip today to hopefully wire it up by this evening.
Thanks a bunch!
LinkBack URL
About LinkBacks
] elliminate it between the twisted/braided cables. It won't help elliminate issues w/ cables which aren't twisted in..[at least thats my understanding] I would think that straight DC power cables from the power supply over to the Servo Drives should be ok un-shielded, or just braided/twisted. Everything else should be in a shielded cable however.. Everything which is TTL or low voltage should be in a shielded cable as well. For the most part, if your going to have to buy the cable anyway, you might as well shield it all.. at least, where you can.
