Old 05-31-2007, 12:50 PM
dan_the_welder is on a distinguished road
Harbor Freight Mirco Mill Drill COnversion
Hi Everyone,
Just finished the motor mounts on a Harbor Freight/Central Machinery Micro Mill Drill.
It's not fancy, but will get the job done.
The little blue thing on the leadscrews is a thrust bearing from McMaster with a couple of belville washers, or disc springs, to keep the backlash out. One on the front and one on the back. You have to compress the springs and use the coupling to hold the tension.
The leadscrew shafts are 8 mm but a 5/16 lovejoy coupler slides on perfectly. I had intended to bore them, but it was unnessicary.
There is not enough machined shaft for the two thrust bearings, belville washers and coupler. Rather than machine the lead screw and lose some table travel, I bored out the back of the mount and nestled the bearing in there on both the X and Y. The Z got machined a little bit to get some extra shaft length.
I discovered my steppers did not have enough torque to lift the head so I made the step down gear train out of threading gears from my old mini lathe. I machined the hubs for the gears from some aluminum bar stock. They are pressed , keyed and loctited on.
Should be cool, we are going to machine some circuit boards with this mill.
Dan
P.S. If you want to see my 4 by 8 router it is here http://www.cnczone.com/forums/showthread.php?t=37510
ID:	38274   Click image for larger version
ID:	38275   Click image for larger version
ID:	38276   Click image for larger version
ID:	38278   Click image for larger version
ID:	38279   Click image for larger version
ID:	38280   Click image for larger version
Old 05-31-2007, 01:27 PM
Mtncrzr is on a distinguished road
Looks Good
Awesome! I am getting an x1 clone today and will convert too.
Old 05-31-2007, 10:37 PM
Tested it......a little!
Took it over to it's new home this evening and were able to move an axis at a time.
Silly but seeing the machine move for the first time is always a real thrill.
Dan
Old 06-01-2007, 06:24 AM
MIKE JEFFERS is on a distinguished road
those steppers look small
is that an rs250 or a 125 i see must be rare in the us
bit of a 2t nut meself
mike
Old 06-01-2007, 01:25 PM
Background stuff.
Hey Mike,
You have sharp eyes. That bike right there is an RS50 replica, which fell into my hands without a motor.
Arriving soon is a 70's CB125 which will provide the motor and one of these, thus creating the CB125RS Turbo.
Heh, should be sick.
My first custom bike is below, homemade rigid frame, Suzuki 400cc motor and the wheels and fork off of a EX500 Ninja. Christened "Half a Harley"
Dan
ID:	38332   Click image for larger version
Old 06-01-2007, 07:52 PM
project5k's Avatar
project5k is on a distinguished road
oh i do like that tiny turbo... wonder if i could use something like that on my toy....
Name:	front left of trikess.jpg‎
ID:	38378   Click image for larger version
Name:	right rear of trikess.jpg‎
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 06-04-2007, 12:59 PM
Wild Ride
Hey Man,
That is a wild ride. Is it from a kit or did you make it from scratch. I love the VW lines.
Dan
Harbor Freight mill conversion to cnc jhowelb Benchtop Machines 30 05-17-2010 08:58 AM
Harbor Freight Mill/Lathe Combo Conversion? griffithbuilt General Metal Working Machines 9 06-17-2007 12:23 PM
Harbor Freight Mini Mill(X2) Conversion List Tim Wiltse Benchtop Machines 3 10-11-2006 06:18 PM
Harbor Freight Mill/Drill Zumba Benchtop Machines 10 03-20-2006 01:08 PM
Harbor Freight Mill/Drill Conversion Log Halfnutz Vertical Mill, Lathe Project Log 31 04-13-2005 10:56 PM
