Old 05-24-2007, 06:57 PM
Astroguy is on a distinguished road
ER16 collets
OK, I bought a set of collets off e-bay http://cgi.ebay.com/ws/eBayISAPI.dll...0165&rd=1&rd=1
The problem is with the 3/8th collet, When I snap it into the Taig ER16 collet nut I can not fit a 3/8 shank end mill in it. I measured it and it is .359 ID when snapped into the nut. So do I have a bad collet or nut? How do I tell?
Boy, I thought this was going to be easy and I have not even milled my first piece yet.
Old 05-24-2007, 07:35 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
wouldn t surprise me if it the collet , the guys stuff is china garbage , ive dealt with that clown with a different product,
downright ignorant !!!
Old 05-25-2007, 02:23 PM
cartertool is on a distinguished road
The 3/8" ER collet is usually 10mm, so larger than 3/8" bore. So it sounds like you got a defective, or wrong size one.
Nick Carter
Largest resource on the web about Taig lathes and mills
www.cartertools.com
Old 05-25-2007, 03:12 PM
HuFlungDung's Avatar
Moderator
There is a mix of collet nuts out there. Whenever I have had trouble like that, it is due to a different specification on the collet nut, or somebody goofed, but when the collet is sitting free, if you can get a 3/8 tool in it (without force), then the collet is okay, but the nut is not. So then as Carter said, you might need to search around for a metric series collet in 10mm, but just be aware that there are some collet sets which are made directly for inch series shanks.
Old 05-25-2007, 05:09 PM
I can get a 3/8 shank in it no problem when out of the nut.
I went to southern tool and picked up a 10mm and it works fine.
Thanks for all the help guys.
Old 05-26-2007, 02:05 PM
That sounds like the snap ring groove isn't deep enough, causing the collet to contract when snapped into the closer/nut
Nick Carter
www.cartertools.com
Are all R8 collets the same? SCCoupe Benchtop Machines 14 07-01-2006 11:33 AM
Collets? how and why? ZipSnipe Benchtop Machines 22 05-29-2006 08:31 PM
Where to get ER 16 Collets Ozinus Benchtop Machines 5 02-24-2006 10:09 PM
ER16 8* taper = OK to use for QTC (ATC)? nicad General Metal Working Machines 6 08-24-2005 10:05 AM
looking for ER16 collet specs nicad Benchtop Machines 1 08-15-2005 08:20 AM
