Results 1 to 4 of 4
Thread: Closed Loop Software?
    Jun 2004
    I am on a Mach3 run X3 with servos and optical encoders.
    I seem to be having a constant issue where noise from who knows where is moving the servos. I thought the purpose of optical encoders would prevent this from happening.
    How does one set up a closed loop system so if the servo moves from an outside signal or force the software senses it and corrects the movement?
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by replicapro View Post
    The noise is probably on the encoder lines.
    You can't with Mach3, but I think the new EMC can.
    Jun 2004
    I just looked at the user manual for EMC and did a search in the PDF document for the term closed loop and didnt find anything. Is there a different term?
    Dec 2003
    If you have encoder feedback noise, it is going to cause problems whatever system is used, using differential encoders, will avoid the noise problem to a great degree, other steps, like proper encoder cabling and shielding prevent and reduce any noise that can affect the feedback signal.
    With a completely closed loop system, encoder signal error can be detected and the system can be halted on error.
    Encoders, when they are working as they should, only inform the control as to the exact position of the servo, this is dependant on a valid encoder signal.
  1. Closed loop vs. open loop
    By pelesl in forum Benchtop Machines
    Last Post: 04-06-2007, 05:56 PM
  2. Lathe conversion - open loop vs closed loop
    By bhowden in forum General Metal Working Machines
    Last Post: 03-21-2006, 04:56 PM
  3. Closed loop software
    By cbass in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 07-19-2005, 12:49 PM
  4. Closed loop....open loop?
    By DAB_Design in forum General Electronics Discussion
    Last Post: 06-26-2004, 05:02 PM
  5. Closed Loop Driver vs. Closed Loop Computer
    By ojibberish in forum Gecko Drives
    Last Post: 06-08-2004, 12:30 PM
