Although those will work, wou would be better off with somting a little more solid, most of the those now come with mdf or laminate surface. I would say butcher block or a hefty gauge steel would be best, if you are using an old one then more then likely it will be fine. It seems as of late at least people have not been putting a lot of thought into there tables and that is causing them problems.
chris
LinkBack URL
About LinkBacks
