Old 04-07-2007, 09:17 PM
leeschaumberg is on a distinguished road
Post BenchTop Mill to Buy
Hi All
I am going to buy a new small verticle mill. Either I will convert it to CNC or buy a mill from CNCMasters ready to go for $6000 with a base. The non CNC mills I am looking at cost about $2700. Did any body out there do this? Any info that you have would be welcome. Thanks in advance Lee
Old 04-08-2007, 07:57 AM
philbur is on a distinguished road
Hi Lee,
To put it straight I think you would be crazy to buy the CNCmaster. It's a round column RF30 clone. About the worst possible choice for CNC (at least when you are spending USD 6,000).
If you want ready built at the USD 6,000 mark you should be looking at Tormach, Smithy CNC or a ready built IH.
Tormach - has a track record but only one alternative (ready built) and no servo option.
Smithy CNC - has a large range of build yourself alternatives but no apparent track record.
IH - has the biggest envelope plus build yourself or ready built options but no apparent track record with the current owner.
CNCmaster - is just a dinosaur.
Opinions may vary.
Regards
Phil
Originally Posted by leeschaumberg View Post
Hi All
Old 04-08-2007, 07:05 PM
Smile Mill to Buy
Philbur
Thanks for the info. I'll check those 3.
Lee
Old 04-10-2007, 06:45 AM
Post Mill to Buy
After some more looking and reading , I've decided on the IH mill/drill. This 2200 all manual mill has a 4500 CNC kit available. Weight of the mill is 950 pounds so it's not an X1. They use it to make thier parts so it works. To get all the info visit thier website at www.industrialhobbies.com.
Old 04-10-2007, 07:34 AM
A kit works if you have the skill and time to make it work. Judging by your initial questions you are new to CNC. I trust you are aware of the job you are taking on with a kit. It’s not quite as simple as bolt together and go. If you figure your time is worth much more than about $5/hour you should reconsider the ready to run out of the box alternative. The only real advantages of "building yourself" is for the challenge and the knowledge you gain.
If you go with the IH + kit you should join the IH forum on CNCzone. In fact I recommend you spend a couple of weeks reading through past posts before you decide on the kit. There is a mass of experience there.
You will also need to think about lubrication, system way-covers, housing the electronics, etc, etc.
Opinions may vary.
Good Luck
Phil
Old 04-10-2007, 07:45 AM
Deviant is on a distinguished road
You need to state what your work envelope is and how much room you have to store one of these beasts.
Also, what level of precision your expecting.
I agree with the above posts reguarding the round columns. Ideally, you'd stay away from those.
Old 04-10-2007, 09:47 AM
Smile IH Mill
Philbur
Thanks for the response
Following are answers to your questions
The Skill - Worked for 4 engine manufactures in Engineering and Research
Fluent in electrical devices and wiring
Very knowledgeable regarding mechanical devices
Drag raced a stock 427 cu inch 425 hp camaro in A stock class
Instrument rated Com pilot
Com drivers license rated (ABCD and M)
Many ((thousands of dyno runs)) on internal combustion engines
The max was 5043 hp at 1000 rpm (4875 rated at 1000 rpm)
Worked as a field service engineer
Own many tools of all kinds
Manufacture special snowmobiles
Yes I'm new to CNC milling
Any job can be long and difficult
When I build it myself I learn alot
I belong to a very good CNC forumn the CNC ZONE
Lube oil not grease
Way covers are good all the time
The electronics and controls need to be securely mounted
So I think I can fiNgure it out
Deviant
Machine 1 of 2 crankcase halves sized like a lycoming 360
Precision should be comparable to normal crankcases
The square column is the way to go
Lee
Old 04-10-2007, 01:23 PM
Sorry Lee, but it did seem that a person who switches from a plan to buy a ready to go CNCed round column to a IH + kit within the space of a few days could possibly benefit from some encouragement to research their plan a bit further, before laying done their time and their money.
Manufacturing large, critical aeroplane engine components will certainly be a challenge.
Good Luck
Phil
Philbur
Lube oil not grease
Deviant
Lee
Old 04-10-2007, 04:57 PM
Post Machine Engine Crankcase
Phil
Yes I wan't to machine my own crankcase. A flat four diesel. A two stroke diesel. A two stroke diesel has been built for a long time and is well proven. (THE DDA) Compressing the intake air is required to start and is good for a plane engine that flies at altitude. I'm sorry if my brain goes so fast. But my ESP is still garbage.
Lee
Has anyone seen this benchtop mill before ? jeff2005 Benchtop Machines 6 02-11-2007 09:46 AM
Not Exactly a Benchtop Mill dcprecision Benchtop Machines 11 09-28-2006 09:58 AM
i like this benchtop belt mill ataxy Benchtop Machines 0 09-13-2006 12:55 PM
Bench for a Benchtop Mill Novah Benchtop Machines 12 10-27-2005 09:50 PM
