I am wanting to try out a flood coolant system on my sherline mill. And later move it to a X3 when i get it ready. Anyone know of a good cheap system to get started with? 1-5 gall I would think. I saw one on MSC by little giant for about $100, is that worth starting with? Also, what coolant to get, I will be indoors where the odor could be a issue if to bad.
__________________ ***For full up to date details visit my blog @ www.donald-neisler.com Donald Neisler |
| Yeah, I got just about finished my enclosure, not the best, but it is made of 2x4's and plexi glass. I will have to check out HF.
| Ron, I just searched Harbor Freight and couldn't find any coolant systems. Any idea what the number was, or anything else to help find it? I'm starting to prepare for my IH mill to get here in a few weeks. thanks - Ken |
| I'm using a 5 gallon bucket and a little giant submersible pump on my bridgeport. about $50 for the pump, had the bucket. I put a cheap screen inside the bucket to catch any chips that made it through the drain pipe which goes from the table back to the bucket. Matt |
| I just added flood coolant to my Taig for under $100. Here's my setup:
I run the whole shebang from a solid-state relay via Mach3 ---Will Chapman : BrickArms.com |
| I was just at Harbor Freight today and wished I had saw this post prior to going. I have a little giant that only has a one gallon capacity, which is way too small, so I place the unit in a larger square (or rectangular shaped) storage container, and drilled a couple of good size holes in the one gallon little giant so that I could increase the coolant capacity to about 4 gallons. Next time I'm at harbor freight, I will find the $40 coolant system and write down the part number. Ron |
| Kitty litter often comes in nice square buckets with lids that close, but not so firmly that you would spill the contents when you open them. The one I am looking at is polypropylene, which is pretty resistant to chemicals. It's hard glue anything to it without special adhesives. Using care, you can scrape off the purple label with a utility knife blade...so I've heard : ) I've been thinking that a ground fault interrupter would be a nice addition to a AC pump system. Last edited by BrendaEM; 05-10-2007 at 06:32 PM. |
#10
| I've been looking at KoolMist because I want something thats cheap, eco-friendly, and easy to dispose of. Is there a magic ratio of KoolMist and water that would totally prevent the cast iron from rusting? Last edited by BrendaEM; 05-10-2007 at 05:43 PM. |
#11
| BrendaEM, If you have the air supply, why not have one of the micro-drop peddlers bring you a demonstration unit to try? They use the bio-degradeable vegetable oil in almost dry machining. Works great from personal experience. There are quite a few brands out there now. You still need to control wayward chips etc. even though there is practically no residual coolant.
__________________ DZASTR |
| Flood coolant on steroids | Scott_bob | Machine Problems, Solutions , Wireless DNC, serial port | 7 | 04-30-2007 01:07 PM |
| Mister versus flood versus ??? coolant system | split63 | Bridgeport and Hardinge Mills | 14 | 10-02-2006 05:18 AM |
| Flood Coolant Pump | rcazwillis | General Metalwork Discussion | 5 | 11-15-2005 01:19 PM |
| question about flood coolant | nicad | General Metalwork Discussion | 6 | 10-24-2005 10:03 PM |
| Cheap coolant system | georgebarr | General Metal Working Machines | 8 | 04-07-2004 02:03 PM |
