04-20-2007, 01:29 AM
Originally Posted by wizard I guess this is another point I have to disagree with. It is always worth the expense of having measuring tools more accurate than your machining tools. Otherwise how do you really achieve anything on the tool?
Maybe others will disagree but I see the ability to measure better than your machine as being a key to doing quality work. After all wear in leadscrews and ways happen and a machinist has to compensate for that. Without do tools you won't know how or where to do so. For many here that won't mean a lot of tools either, maybe a good caliper and a micrometer. Relative to the cost of everything else it just seems silly to cut corners here. Given that you buy a good caliper and a micrometer you might be out say $225 which is maybe a tenth of the cost of a well outfitted small lathe. Frankly I'd cut corners in other ways such as making my own tooling and such then to go with questionable measuring tools.
Maybe my priorities are different than others here but starting out with good basics is a win in the long term.
dave
Dave |
Dave, I don't disagree with you, but there are times and circumstances that its not always needed either. The ideal and the reality are almost always two seperate things, if I were doing this as a my one and only job then I am entirely inclined to agree with you. This does not excuse subpar work or craftsman ship, but the ablity to do the work(buying the machine and vise) supersedes the ablity to measure it.... In my particluar case finish is of the outmost importance, flatness is second, niether of which I use precision insturments on(unless you consider a cheap surface plate). The actual measurement needs to be with .010 of defined thickness and thats it, as long as I am clean and flat(via blueing) and over my min thickness I am very happy. Thats not say I do other things, but those typically don't need to be that close. If I was making parts for the medical industry, well then yes I would be using the cadilac of tools. I agree with you on making tools, and I think alot people would benefit from making there own tools, I think to many people run to carbide, when they could be or should be using something else which would have been much cheaper and better.
chris |
