Old 03-27-2007, 09:01 AM
Gold Member
InspirationTool is on a distinguished road
Table tray for coolant/swarf protection....
I have a Syil X2 and KDNTOOL XJ-95. The tables are about the same width.
I've had concerns with the amount of coolant and swarf running over the ways and screws, as well as the coolant and chips packing the T slots.
So, I made a table cover, and so far, I REALLY like it. It keeps almost all the coolant and chips off of the ways. You still need bellows, but this makes the bellows have to deal with ALOT less, and it is cheaper than full coverage bellows.
For more pictures and comments, check out:
http://www.jeffalbro.net/cnc/table-tray/
-Jeff
Old 03-27-2007, 05:21 PM
digits is on a distinguished road
That looks nice, and I'd be glad to never have to clean my T-slots again, but do you have any noise/resonance issues with that thin steel sheet?
Old 03-27-2007, 07:25 PM
Gold Member
I've done flycutting, engraving, and milling on it, and I haven't found an increase in noise.
Some thing I need to add to the web page... you DO get some coolant through the edges of the bolt holes into the table if you don't seal it, but I have a drainage hole at the end of the table, so it's not a problem.
-Jeff
Old 03-28-2007, 07:04 PM
Glad to hear it works well - coolant always gets everywhere you thought it couldn't
Do you only every use a vice on your table, or are you going to make a tray per setup? Also, isn't there a danger of rust forming from the little coolant that does get through if you've permanently got that tray on there?
Cheers.
Old 03-28-2007, 07:17 PM
Gold Member
I just use the vise. If I had to, I would pull the tray and run a job without it.
I've made some vise mounted pallets for some jobs.
There is a danger of rust, but I haven't seen any under the vise even after several months when I wasn't using the tray. Only some staining.
So, I'm not going to worry about it. Time will tell.
-Jeff
Old 03-28-2007, 10:10 PM
Burn is on a distinguished road
What thickness of stainless did you use? I am very interested in making one for my Taig. Any advice to someone who is going to make it themselves?
Old 03-29-2007, 08:01 AM
Gold Member
I *think* it was about 16 gauge. But as it isn't structural, just about anything will work.
I had my welder make it for $50. If you have a shear, corner notcher, and bending brake, it should be a piece of cake. If you don't, you could probably do it with a jig saw, a vise, and a hammer, but it wouldn't be pretty.
I used a hand held drill to make the vise bolt holes.
-Jeff
Old 03-29-2007, 03:25 PM
Gold Member
I moved the try to my other mill today, and did find a little bit of rust. I used a bunch more rust protectant on the other mill. Hopefully, that will fix things.
-Jeff
Old 02-10-2011, 12:13 PM
MtlWrx is on a distinguished road
Coolant tray
Here is a coolant tray I designed and had made. Interested? I can have it customized for your machine. The unique thing is the upper left and right sides make it easy to run large work, there are windows in each side to make it easy to run longer tubes.
Old 02-10-2011, 06:13 PM
rwskinner is on a distinguished road
The links to the pictures on your site are broken.....
» Mill Table Tray Jeff Albro
-Jeff
Rev
SX-3 Mill, 10x22 Lathe, RF-45 Mill, GH-1340 Enco Lathe
  #11   Ban this user!
Old 02-11-2011, 04:05 PM
fragger6662000's Avatar
fragger6662000 is on a distinguished road
it seams a lot of work to avoid using a wet and dry vac.
do you not run it to issues of reach / clearance and rigidity when machining high up in a vice.
  #12   Ban this user!
Old 02-11-2011, 04:32 PM
I do use a wet dry vac, but this keeps the shop clean and saves a ton of money on coolant. No issues with rigidity as it just sits there.
Coolant tray for X3 oldtool Polls 1 02-10-2011 12:11 PM
Coolant Table impact General Metal Working Machines 5 03-11-2006 08:50 PM
Problems with Swarf Protection. Willyb General Metal Working Machines 0 02-07-2005 02:29 PM
Tip up protection for plasma table dpaulson CNC Plasma and Waterjet Machines 0 01-25-2005 04:36 PM
Coolant & Swarf problems on Homebrew CNC Systems UKRobotics General Metal Working Machines 1 01-18-2005 12:26 AM
