  #13   Ban this user!
Old 02-12-2011, 09:35 AM
Fastest1 is on a distinguished road
Btw if you dont have rust on your table after using a tray, you are just lucky. I have used that way and it worked decent but made tool changes more difficult and did get rust and staining if not removed often. After trying many different ways of swarf and coolant control finally I went and got a quote from the local sheet metal shop a couple of blocks away. For a base tray similar to Hoss' in 16 gauge with angle sides was quoted at 135.00. I plan on mounting 80/20 sides and retracting door. Supposed to be ready by friday but I have a few changes to give them, such as chip tray of some sort. Pictures soon.
Originally Posted by MtlWrx View Post
Here is a coolant tray I designed and had made. Interested? I can have it customized for your machine. The unique thing is the upper left and right sides make it easy to run large work, there are windows in each side to make it easy to run longer tubes.
Coolant tray for X3 oldtool Polls 1 02-10-2011 11:11 AM
Coolant Table impact General Metal Working Machines 5 03-11-2006 07:50 PM
Problems with Swarf Protection. Willyb General Metal Working Machines 0 02-07-2005 01:29 PM
Tip up protection for plasma table dpaulson CNC Plasma and Waterjet Machines 0 01-25-2005 03:36 PM
Coolant & Swarf problems on Homebrew CNC Systems UKRobotics General Metal Working Machines 1 01-17-2005 11:26 PM
