Old 03-23-2007, 01:13 PM
billsp is on a distinguished road
Smile Stepper physical connectins
I'm considering the purchase of a Sieg X3 and converting it to CNC. I was wondering the pros and cons between direct coupled stepper motors on the X, Y, & Z axis and offset steppers with a gear and belt?
thanks
Old 03-23-2007, 03:59 PM
philbur is on a distinguished road
Correctly designed direct drive works fine. Why complicate it.
Phil
thanks
Old 03-23-2007, 05:11 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Well, for starters - using a belt and pulleys allows you to effectively multiply the output (torque) potential from the motors and increase your potential accuracy. The cost of doing so is that you loose some speed.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 03-23-2007, 05:53 PM
You could just use a bigger stepper with direct drive. The normal issue with steppers is they are to slow for decent rapids so gearing down just makes it worse.
The critical issue with steppers is you need a bit extra in the size department in order to avoid the risk of lost steps.
A direct drive will give more than enough accuracy for the capabilities of an X3.
Just some thoughts from a novice.
Phil
Scott
Old 03-26-2007, 11:12 AM
in2steam is on a distinguished road
Scott
You loose speed in proportion to the amount of torque you gain not including loses for friction of the belt which can be enough to make a difference. I am direct coupling, this size machine and the average size stepper will be just fine. The only benefit I have seen in the belt drive is getting the stepper out of the way.
chris
tracing physical samples into CAD mark_christians WoodWorking 4 03-09-2007 01:03 PM
duplicating existing physical item/pattern memilanuk WoodWorking 3 05-29-2006 12:43 PM
Feedback Calibration vs Physical Alignment jdownie DIY-CNC Router Table Machines 7 03-23-2006 10:03 AM
stepper motor size(physical) Bloy2004 Stepper Motors and Drives 4 06-22-2004 09:31 PM
Physical difference between a stepper,servo and a DC motor ynneb General Electronics Discussion 1 02-22-2004 11:40 PM
