Results 1 to 7 of 7
Thread: Where can I find a 12mm 2.5 pitch lead nut
    Jan 2007
    Question Where can I find a 12mm 2.5 pitch lead nut
    Does anyone know where I can find a 12mm 2.5 pitch lead nut for an acme lead screw? I can make two into a antibacklash set-up if I need to.
    thanks
    Dec 2006
    M12 x 2.5
    I just have to ask since the pitch is so close......are you sure this isn't 1/2"-10 which would be soooo much easier to find?
    Dave
    Jan 2007
    lead nut
    I know, I wish that is was 1/2" by 10, but the major diameter is .475" ish not .500", so I am pretty sure that is a 12mm. Thanks
    dave
    Sep 2006
    Sweden
    I would not rule out 1/2" yet, 0.475" is more like 12.1 mm and OD of TR12 is closer to 11.8mm. (http://www.gewinde-normen.de/en/trap...se-thread.html)
    Jan 2007
    Tr?
    What does TR stand for? Thanks
    Sep 2006
    Sweden
    TR = Trapezoidal, I think. Normal way to specify a trapezoidal screw is Tr12x3 for example (major dia. x pitch). Click the link, it's a handy resource for a variety of standards, not ACME threads though.
    Jan 2007
    a pic of my lead nut
    So with all this thread engagment, there is so much friction that I can barley turn it by hand. And I have tried to take the spring off.
    dave
    Attached Thumbnails Attached Thumbnails Where can I find a 12mm 2.5 pitch lead nut-lead_nut.jpg
    1. Have a gear but need to find out pitch to cut matching set (pic attached)
      By rkremser in forum Mechanical Calculations/Engineering Design
      Last Post: 11-10-2006, 09:52 PM
    2. Different leadswcrew pitch on X&Y ?
      By vacpress in forum Linear and Rotary Motion
      Last Post: 04-03-2006, 09:46 PM
    3. gear pitch
      By 2muchstuff in forum Mechanical Calculations/Engineering Design
      Last Post: 04-02-2005, 09:04 AM
    4. New Ballscrew Pitch?
      By barkster in forum DIY CNC Router Table Machines
      Last Post: 12-06-2004, 10:02 AM
    5. Lead, pitch, start?
      By sixpence in forum DIY CNC Router Table Machines
      Last Post: 01-30-2004, 04:07 PM
