Old 03-10-2007, 06:34 PM
greasetattoo's Avatar
greasetattoo is on a distinguished road
Sherline 5400 Motor Hot
Hello,
Does anyone know how long you can run the Sherline 5400 Mill. I just ran mine for about 9 hours on High and the motor seems kinda warm...I can rest my hand on it for about 3 or 4 seconds. Is this normal..
thanks
Grease
Old 03-10-2007, 11:27 PM
BrendaEM is on a distinguished road
Perhaps a small muffin cooling fan aimed at the motor might add a little cheap insurance. Also you might find a way of attaching some old heatsinks to the motor without blocking any existing cooling holes. Sigh, if only you had a mill you could really make something : )
An old trick that some electric vehicle people sometimes use, is seating the motor to its attachment with heat sink compound.
I've seen people use small squirrel cage blowers and plastic hose to force cool motors.
Any of the above may void your warrantee.
Old 03-11-2007, 12:10 AM
GeneK is on a distinguished road
Sounds about normal to me. i have a couple of Sherline lathes and mills. The only time I had the temp cut out go off was using a 3/8" bit in a 10,000 rpm set up. One cnc project I ran went for 9 hours, the motor was at 140 deg.f and the head stock was 105.f
GeneK
Sherline 5400, X2, or Taig? tipschips Taig Mills & Lathes 20 08-01-2006 09:25 PM
Electrical Motor Noise Sherline Mill JohnAn Machine Problems, Solutions , Wireless DNC, serial port 2 01-03-2006 09:33 AM
Looking For The Best Sherline Cnc Kit BUD B DeskCNC Controller Board 1 12-08-2005 10:04 AM
sherline 5400 Preload nut dneisler Benchtop Machines 1 11-28-2005 12:40 PM
Picture of Flashcut 5400 limit switch JJPPHH FlashCut CNC 0 03-30-2005 10:58 AM
