| Interface cards for Emco Mills & Lathes I am an intructor at a Tec school that has 12 Emco trainer lathes and mills. The problem we have is the interface cards will not run on any sofware newer than Win98. The I.T. department here can not support the computers that are running the machines anymore, so we have to upgrade the pc's. Emco wants a lot of money for there cards that will work in XP, so I am looking around to see if there are other cards that might work with the trainers. Any help would be greatly appreciated. Thanks Ken |
| WELsoft Ken you might try www.WELsoft.com thay make a up grade for those lathes. Deane |
| emco Dear ken, Its a known problem, I think you mean the rs485 (isa) cards whitch are used on the emco pc mill50 and pcturn 50. Unfortunately I dont think theres asolution for it based on the hardware that you have. I'ts not even the interface card thats the problem but even the software says when its installed that it will only work on win98. I think there could be 2 options.... Convert the machines so they will work with mach3 software or make the pc's dual boot so that when needed can be used in xp or vista and when using the emco's reboot to 98. (btw i'll send you a pm because i have a favor to ask you) Best regards Binski |
| Its a known problem, I think you mean the isa rs485 interface cards that are used withe the emco pc-mill and pc turn 50 cards. If that is what you mean than i dont think there is a cheap solution. Even when installing the software it asks for windows 98. You could do 2 things, convert the machines so they will work with mach 3 or dual boot the pc's. so when needed boot up in xp/vista and when using the emco's boot up in win 98.. Good luck best regards Binski |
| hi guys... need help..... we have this EMCO compact 5 CNC lathe machine... the thing is... we dont know where the problem lies whether its in the RS 232 communication or the lathe machine itself b'coz the lathe machine indicates program loaded... from the PC but then the CNC will not run the program after we pressed the start button on the cnc Last edited by c_aguit; 11-07-2007 at 10:08 PM. |
| Emco Compact5 Interface (like Weledit) | mikkojay | Visual Basic | 43 | 06-05-2010 05:33 PM |
| Emco mills | sackbut | Benchtop Machines | 12 | 03-08-2008 01:15 AM |
| Interface cards for Emco Mills & Lathes | kcarey | DeskCNC Controller Board | 6 | 05-01-2007 01:41 PM |
| Birmingham Mills and Lathes | smilenbseen | General Metal Working Machines | 23 | 01-22-2007 07:19 PM |
| Clausing's Storm Mills & Lathes | leggetmachine | General Metal Working Machines | 2 | 07-18-2006 11:24 AM |
