Results 1 to 4 of 4
Thread: How to remove gearhead cover?
    Jan 2007
    Can someone tell me how to remove the cover from my gearhead square column (WT) mill ?
    I removed the motor and the six bolts securing the cover, but when I lift it up it gets stuck about 2 inches up. It looks like all the gears are coming up with the cover ?!? Should this be the case?
    I also can't get it back on flush with the head, it gets stuck about a quarter inch from the head. I seem to be stuck here.
    Jan 2007
    Texas!
    Hi, Maybe ask in the Industrial Hobbies section of this forum, I would think one of those guys have had there mill apart and they should be pretty cose to identical design as far as the gear head goes. Im curious too, I have a mill like yours Good luck, Dave
    Jan 2007
    Texas!
    Hey heres a post showing all kinds of info on changing seals in the IH head IH Gasket Repair help
    Jan 2006
    The gearshift yokes are getting hung up in thier slots. Move the gear shift levers around and the gear column should fall back in and the yoke will be free. You can then lift the gear cover off.
  1. can i use this gearhead ?
    By max_imum2000 in forum Linear and Rotary Motion
    Last Post: 01-27-2007, 09:02 PM
  2. How to remove way covers?
    By damae in forum Bridgeport and Hardinge Mills
    Last Post: 01-09-2006, 04:50 PM
  3. Planetary gearhead vs timing belts
    By Swede in forum General Metal Working Machines
    Last Post: 03-27-2005, 09:19 PM
  4. How to remove THK carriages?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 08-12-2004, 07:04 PM
