Old 02-21-2007, 11:22 PM
kdoerksen is on a distinguished road
X3 CNC Fusion kit with upgraded bearings?
The CNC Fusion ballscrew CNC conversion looks compelling, though I've heard many comments that using the X3's stock bearings is insufficient. For those who have experience with the kit, would it be possible to upgrade to angular contact bearings in a straightforward manner? Is there a simple part-replacement solution (ie: improved bearings that would fit the existing bores) out there?
Thanks.
Old 02-22-2007, 10:15 AM
gtschance is on a distinguished road
I have searched for high quality AC bearings of the same size and so far not found any that would fit. I do not claim I have made an exhaustive search.
The ISO model number for the standard 3 piece thrust ball bearings is:
51101 and the dimensions are:
OD:26mm
W:9 mm
My understanding about fit for AC bearings is as follows:
ID - must be absolutely right
OD - must be very, very close to right
Depth - you can easily get away with bearings of lesser width (meaning depth of pocket) as long as your mechanism to tighten (load) fits inside the pocket (high tolerance spacers apparently work). It has been suggested to me that having a bearing marginally too wide (say a 10mm width bearing in a 9mm pocket) would also be OK.
So far, all the "good" (expensive) AC bearings I have found with a 12mm ID are too big in OD which would require machining the diameter of the pocket larger.
If you find any please post your results!
Regards,
George
Old 05-09-2008, 08:58 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
The CNC Fusion Deluxe X3 kit now comes with AC bearings for X and Y axes.
CR.
Upgraded postprocessors Alan L Hypermill 7 01-03-2007 12:22 PM
My upgraded machine and cabinet Parameter CNC Wood Router Project Log 17 11-22-2005 02:51 PM
Upgraded to 4.0, now only X axis works?? Mueller TurboCNC 1 10-04-2005 11:23 AM
We upgraded to 2005. duluthboat FeatureCAM CAD/CAM 5 05-01-2005 10:41 AM
Well I upgraded to XP pro WallCrawler Computers and Networking 12 02-23-2004 04:54 PM
