  #49   Ban this user!
Old 07-17-2007, 03:23 PM
impact is on a distinguished road
Couple more shots from my table, if its any help to anyone.
  #50   Ban this user!
Old 07-17-2007, 09:43 PM
Harryman is on a distinguished road
I don't know if anyone uses a waterfall separator with their coolant, they work pretty well to get rid of most of the fines before it gets back to your pump.
All you need is 2 containers, the first with a baffle forcing the fluid to go down under it before coming up to the drain leading to the next container. The pump is in the second one. 5 gal buckets, big tupperware, whatever you have around and some plumbing fittings. A coarse screen leading in and you're good to go.
  #51   Ban this user!
Old 07-18-2007, 03:07 AM
digits is on a distinguished road
Cheers, that is a good idea! I take it the baffle has to be properly sealed against the sides to prevent the coolant short-circuiting across the top and leaving a lot of stagnant liquid in the bottom?
I am hoping though that my chip bucket will become self filtering if I'm too lazy to empty it often enough - all my 40mm drain piping has ended up blocked with curly chips which self assemble into metal scourers!
  #52   Ban this user!
Old 07-18-2007, 08:41 AM
While it would be nice, the baffle doesn't have to be perfectly sealed, as long as the edges are fairly true, you can just slide it up against the wall in a round bucket and it'll be fine. If it's not sealed it's also easy to remove when you have to clean out the bucket.
I used to use this system for recirculating water in a tumbler with 3, 60 Gal drums and multiple baffles. It would go in looking like mud and finish almost clear.
Vibration reduction.. JerryFlyGuy Mechanical Calculations/Engineering Design 34 11-09-2008 08:33 AM
T-Slot tables coolman DIY-CNC Router Table Machines 3 05-26-2006 01:30 PM
Tool Tables mmorton9 Mach Mill 2 01-17-2006 04:01 AM
What do you think about these tables xairflyer DIY-CNC Router Table Machines 6 09-09-2005 07:23 AM
looking for the best way to build one of these tables chiliuno CNC Plasma and Waterjet Machines 3 03-31-2005 12:09 AM
