Still pondering my route to CNC - the best overall hardware base for my application appears to be the Taig unit (small parts, mostly brass & aluminum, hobby use - speed of production not really an issue, small (<1/8" tools) - thus high spindle speed an advantage. There are a lot of stepper driven units available - either as turn-key or kits, and a few servo systems (one, in particular, uses relatively small Globe servos with reduction drive to the leadscrews) Conceptually, the servo system, with a closed loop control mechanism, appears to be the better choice albeit typically a bit more expensive. Are there other factors to be considered? - Disadvantages to servo control? My objective is to use a CNC mill as a tool for my hobby - it will not be a hobby itself. thanks EM |
| Its my understanding that servo sytems are more difficult to tune. Also servos mostly come into their own when you want to push the machine close to its limits (as in commercial use) with respect to lost steps. So for hobby use I would not bust a gut in order to have servos. Pricing the two alternatives might help you to decide. Regards Phil
| Servos have some technical advantages as well as some disadvantages. Generally from the standpoint of pursuing an hobby I see steppers winning for most uses. The issue is costs foremost. In your case it should also be an easier system to setup and maintain which is a very good thing if your goal is to support another hobby. The only gotcha here is that you have to be sure that th steppers will be smooth enough at the speeds you will be feeding those small tools. This coming statement may lead to arguments but believe it is much easier to get high quality results from servo systems as opposed to stepper systems. I have no experience with the Taig, from what I hear though it will be an easy machine to get up and running as they do a very nice job of building the machine. That would likely be one of the biggest detractions of converting an import mill. Do realize though that once you have a CNC mill making use of it requires a chain of software tools to generate the code and the drawings from which the code is generated. You of course can hand code CNC code and even use the CNC software to drive the mil manually. It is just that the more complex items require a tool chain to build the CNC code required to generate the product. You may already be aware of this but I point it out due to many not taking into account the software chain needed nor the efforts required to hand code G-code. Dave |
| Sounds like you would be best looking at steppers, not being after ultra speed etc. Also a point to note, hobby servo systems all run on brushed DC motors which can wear out. Stepper motors are zero maintenance brushless. Good if you are after a hobby tool, not a tool hobby |
The micro stepper drives on those machines produce good results, albiet a little on the slow side, they do very fine work such as engravings and ring work very well. I kinda wish taig made a larger unit..... chris. |
| Do a stepper and servo search on the website. There is a very detailed cost/benefit posting by Maris that has been reposted SEVERAL times either via cut and paste or via link. Pretty much ALL the gives and takes are well documented. Each has benefits and liabilities that the user has to be the judge of. BTW, Bridgeport made a lot of machines that used DC brushed motors on VMC's and ExTraks and V2XT's - BPT hardly made whay you'd consider a "hobby" system. |
| chris |
#12
| I think I would have a hard time justifying servos myself. Granted, my stepper system wasn't exactly cheap, but for small machines like mine(Minitech Mill4), I can't imagine much value to a servo system over my current Camtronics Gecko setup. I can easily get over 400ipm reliably with the setup, and without limits, its nice to know that an error will result in lost steps and not destruction or damage to a machine component.
__________________ www.rc-monster.com |
| oz/in. on a servo is it the same as on a stepper? | CATCH22 | Servo Motors and Drives | 3 | 10-14-2006 07:43 PM |
| When to use Servo and When to use Stepper ? | Calico | General Electronics Discussion | 1 | 03-26-2005 10:31 AM |
| Servo vs. Stepper | rackbox | DIY-CNC Router Table Machines | 2 | 11-28-2004 06:23 PM |
| Stepper or servo | lard | General Electronics Discussion | 1 | 11-21-2004 07:57 AM |
| Servo vs. stepper? | rycodog | General Electronics Discussion | 8 | 06-29-2004 09:24 PM |
