Old 01-29-2007, 07:30 PM
lkasdorf is on a distinguished road
Rockwell mill conversion- acme or ball?
I want to do a CNC on my Rockwell knee mill. The acme screws have very little wear. Do you think that with the installation of anti-backlash nuts, that I could do a successful cnc conversion using the existing acme screws?
I guess what I'm asking is- if you have essentially zero-wear acme screws, is it always going to be wanting? I know that there is more drag on an acme system, and that a ball screw it designed for zero lash (right?).
Anyway, I'm just wondering if I should even bother, or just go right to ball screws. If I'm going to go to the trouble, I want something with .001 repeatability.
I only have a about $100 in the mill (part of an excellent package deal), so if I spent a few hundred more, it would not be a huge deal.
This will be my first CNC experience, by the way.
Lynn Kasdorf
Old 01-30-2007, 12:46 AM
Rally's Avatar
Rally is on a distinguished road
Are you for real?? I would start by doing some research!
I would not put a lead screw into anything period! You are taking of doing a CNC conversion for a couple of Hundred?? That is funny!
It would be in your best interest to just use the Mill as is. Sorry if I’m sounding like an As…….. but judging by your question that was the only thing I could say.
However, for what it’s worth, there are books on how to do such conversions.
Old 01-30-2007, 01:04 AM
Rally's Avatar
Ok! I will take some time to explain. First off, it is possible to use standard lead screws but the outcome will not be satisfactory.
When you are saying CNC Conversion are you taking about real CNC results or is your intent just to be able to move a table up and down? Anything is possible!
You need to start by getting an Idea of what it is that you want to do, once you know reply and I will point you in the rite direction.
PS: Expect a quality conversion to be something like $2000 to about $5000.
Old 01-30-2007, 08:17 AM
clarification
I have been doing nothing but research. And I've heard some people say that you can use acme screws and get rid of the lash, but the big disadvantage is the extra drag.
So- your conclusion is to not bother with the Acme screws. Pretty much my conclusion as well, but some folks say you can do it.
The few hundred remark was meant to be the delta between acme screws and rolled ball screws. Probably closer to $1k delta.
I just spotted on this site a glowing review of Roton screw products and the statement that they are way cheaper than McMaster Carr. I'll investigate these folks.
Old 01-30-2007, 08:35 AM
Gold Member
InspirationTool is on a distinguished road
For me the worse problem is that the anti-backlash adjustment requires more frequent adjustment due to the wear of the screws. The ballscrews shouldn't need adjustment very often at all.
-Jeff
Old 01-30-2007, 12:38 PM
Rally's Avatar
I may be wrong but I don't think that Roton has precision ground screws all they carry is rolled. If you are OK with the lesser Quality they will do.
High quality rolled screws usually will be in the 1 to 2 thousand accuracy range whereas a precision ground screw will be more like0.0005 per foot.
If you really want CNC results that that is the way to go. Just Imagine an offset of .002 per foot that would be .004 by the time you run the X to the other side.
Old 01-30-2007, 12:54 PM
Pretorien is on a distinguished road
Is this error cumulative along the length or random within the part?
EM
Old 01-30-2007, 01:04 PM
Rally's Avatar
I don't exactly know, from what I been told the screws will sometimes go out in the process of manufacture. Maybe someone else will help answer that question.
If I was you I would go with ground.
Old 01-31-2007, 03:35 PM
phantomcow2 is on a distinguished road
What do you plan on doing with this mill? Let this guide you as far as what kind of ballscrew you want. Rolled is what 95% of hobbyist use. I recall a thread a while back here on hte zone where somebody tested the 5/8-.2 ballscrew and found it was far better than .004" per foot. Not surprising
Old 01-31-2007, 03:48 PM
.004" would be fine
That seems entirely plausible. I'm sure that roton or other rolled ballscrews would be just fine. It will be used for misc work around the shop, and to make parts for a large CNC router, hopefully. I'm really more concerned with lash than absolute accuracy, i suspect. I might like to use this to cut prototype printed circuit boards- if a trace is off by .004, no big deal. However, if the lash is bad enough to prevent it from making good circles, that would be a problem.
I mostly want to gain experience with a CNC machine and end up with a decent mill in the process, perhaps that I can sell at some point for the next great deal I find
  #11   Ban this user!
Old 01-31-2007, 04:05 PM
I can almost guarantee Roton's stuff is better than .004" per foot. I called them a while ago for pricing info, I recall it was pretty good. I do remember they charged 10 dollars extra if you wanted a preloaded nut. If it was me, I would just get the two non preloaded nuts and mount them properly to make an antibacklash setup.
It would definitely be in your best interest to get ballscrews though. THat way you can use smaller (cheaper) motors.
  #12   Ban this user!
Old 01-31-2007, 04:14 PM
Remember to take pics of the process
acme or ball screw smarbaga Mechanical Calculations/Engineering Design 12 06-10-2010 10:46 PM
taig mini-mill screw conversion: acme or ball? nickydubs Taig Mills & Lathes 1 10-25-2006 11:12 AM
Rockwell Mill smittys800 Bridgeport and Hardinge Mills 0 08-27-2006 10:31 AM
Ball or Acme leadscrew for a small mill? MrRage Knee Vertical Mills 1 12-18-2005 01:53 AM
Mini Mill 5/8 Ball Screw conversion Question rustyolddo Benchtop Machines 3 12-12-2004 12:24 AM
