Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: DIY CNC Mini-Mill?
    Jan 2007
    DIY CNC Mini-Mill?
    Hello everyone.
    Im looking into making a CNC Mini Mill so I can make my own alumnium parts for my R/C's.
    But my problem is I dont know where to start and im on a extremely low budget.
    The max I can spend is $150.
    Is it possible to build a Mini-Mill that can do small alumnium parts for under $150?
    Any help is apreciated.
    Thanks, James
    Feb 2006
    us
    Nope!!
    Jan 2007
    Darn....
    Do you think one like this http://www.hackaday.com/2006/07/12/h...-own-cnc-mill/ will cut small alumnium parts? Because I allready have some Stepper motors from an office printer and Dremel's are pretty cheap.
    Jul 2004
    Even a micro mill will cost double that, then you have the cost of the cnc conversion, tooling, etc.
    Jul 2004
    That would be good for maybe circuit boards or small plastic stuff but it doesn't look rigid enough for cutting aluminum.
    May 2004
    Link,
    While I am still a newbie to CNC myself I just don't think you can do it for $150.00. Just the software alone for the controller is going to cost you that much(Mach3).Add the cost of a CAD program plus drive board. Plus the saying that you will spend many times the cost of the machine in tooling is very very true and that stands true even for a bare bones setup.
    And no I don't think that little machine you had the link to will cut it. You just can't cut metal with a machine made from plastic.
    LAter,
    Tim
    Jan 2007
    I was planning on making the base out of X tubeing (I think thats what its called.) so it will be more rigid.
    Also I allready have CAD (Delmia and AutoCad)
    Feb 2006
    us
    Linkster ya could probably do it real cheap like many others here have done. But $150, it would be a $150 cnc thing. I too plan to build a cnc gantry mill. I also plan to save as much money as possible without sacrificing quality. To cut metal whether its aluminum or steel or whatever. Ya need a degree of accuracy. Ya could do some dumpster diving like JasonMarsha did and probably save quite a bit. But if ya add up the time it takes to put all the different pieces together and getting them to work is another thing. I,d say probably the cheapest ya could do it would be around $500 and thats pushing it. I,m estimating my build to be around $1500(hopefully cheaper) But if I have to pay out more to make it right than so be it. Some the guys on here have set the bar high when it comes to DIY cnc and it really should be about craftsmanship and ingenuity. I push myself to be as good as some of the guys here and you should too. Here,s some links to help ya get started.
    http://www.americanmachinetools.com/...ng_machine.htm
    How to use a Milling Machine
    http://www.hobbycnc.com/
    HobbyCNC.com
    http://www.surpluscenter.com/item.as...c&item=11-2449
    Surplus Center Item Detail
    http://dumpstercnc.com/
    dumpsterCNC - anti-backlash leadnuts
    http://www.vxb.com/Merchant2/merchant.mvc?Screen=SFNT
    Ball Bearings:Ceramic & Miniature Bearings
    Jayson's #2 Machine
    Jayson's #2 Machine - CNCzone.com-The Ultimate Machinist Community
    Zip's CNC Router
    Zip's CNC Router - CNCzone.com-The Ultimate Machinist Community
    Good luck
    Jun 2005
    I saw an article sometime ago where a guy converted a 79 drill press to CNC. He used a little ENCO mill table. While not nearly the ideal CNC setup, he had decent results. Under 150 is a stretch. If you go that route, you can probably do under 250 if you already have steppers and they are strong enough.
    May 2004
    Link,
    Good luck with your project. You still need control software that takes your g-code and tells the machine what to do. Again I think Mach2/3 is the cheapest you will find at $159.00!
    LAter,
    Tim
    Registered acondit's Avatar
    Apr 2005
    Link,
    EMC2 is open source and runs on linux. You can get both for free.
    Alan
    Apr 2003
    Quote Originally Posted by Tim Wiltse View Post
    Link,
    LAter,
    Tim
    No turbocnc is free and 60 dollars to register with source code..
  • Page 1 of 2 12 LastLast
